The AC voltage measured for RMS is the actual one to be used in the calculation, afaik, and a voltmeter will be a valid source if the source is a sine wave.
So, Just to prove the tiny transformers could not make the 2B give 100W at 4 Ohms, (assuming the transformers would deliver 100W max themselves )I did a test.
I was so wrong, it actually DOES give 2x100 watts. (Not saying it will not overheat if continuously)
I used my Burosch analog distortion / volt meter, which has internal 8 Ohms resistors (capable of 200 Watts for 10 minutes, the unit has a fan inside, also).
I routed ONE Bryston channel at a time to BOTH watt meter inputs.
I measured the resistance being 3.8 Ohms for the parallel dummy input. The Keithly DMM199 showed 227VAC as input.
This 2B-LP was originally a 120 Volts unit but in this model there were transformers having double primary windings and a possibility to swap to 230V
The way of measuring was turn up the output voltage, and look at the 0.1% full scale of the (most right) meter on the Burosch, regarding the very moment distortion goes up as max power. Both channels (tested separately) went slightly over 20 Volts AC (20.28 and 20.13), which is over 5 Amps into 3.8 Ohms, so the 100 Watts is reached. Also the analog meters showed about 50 Watts each (read: each analog meter shows the value over its own resistor...). Including its own distortion, the distortion meter shows around 0.025% being 25% of the analog scale. At a certain moment even slightly moving up the voltage suddenly distortion comes in.
Removing the input to the Left distortion meter allawed for more voltage, AC voltage was 23.6 until distortion raised. (over 70 Watts into 7.5 Ohms)
Note this all is 1 kHz only, my analog distortion meter can supply all audio frequencies but only measure at 1 kHz
Also, initially the Dummy loads parallel were 3.74 Ohms but once heated up they were over 3.8 Ohms
For leisure, I attached some pictures. The transformers are even tinier than I remembered....
These are Plitron ones marked as 115 Volts.
Following picture indicates some 0.22% distortion , at the onset of distortion, 0.3% is full scale, signal generator 724 millivolts
Next is two times hitting the 10dB lower switch (20dB lower), signal is 72.4 millivolts. To show how the meter works on autorange is that the meters indicate 50 on the 200 scale, this time the led went down to the 2W scale (I guess only the readers having a good monitor will see), the meter on the far right is some 25% of range on the 0.1% full scale meter setting. Note both dummies/meters have parallel wirring.
The DMM at full power of one of the channels
The DMM at no power, measuring the dummyload
the transformers
Back of the bryston. This one has modules having green leds on the front, and a Bryston-built remote power on PCB, and jacks. This model is a 120 Volts model but having TWO primaries each transformer, so THIS model actually can be turned into a 230 Volts model.
There are also the very old models having very flat big EI transformers, there are ones with black transformers too, and the latest ones from 2007 had plastic transistors instead of TO3, at the same time the cooling outlets on the top were not on the front but on the back of the top plating. Mine has no mains power switch.
BTW the very reason to take of the top plate was to really check that both amp channel power actually IS separate (read: each channel its own transformer and rectifier, NOT coupled together, which could have been a possibility)
Now, take notice of the power transistors. I think remembering Bryston also used MJ15022 and 15023 ones, or 024 and 025 in some models. Could these SJ partnumbers be exactly those well-known ones.....?
