Is a vibrating power transformer consuming power? More to the point, is it OK to have line voltage to a bucking transformer on all the time, or is it better to power it off completely when not in use?
My shop building in the woods has high line voltage. We run Christmas lights to the outhouse. The strings have been burning out too fast, so I set up a 120 - 15V (2A) transformer as a bucking transformer to bring the voltage down from 125 to 110. I mounted it in a junction box and used it to power one socket of a duplex outlet. Works fine. I ran it for awhile and did not notice any heat buildup on the outside of the J-box so I think I did it right.
However, there is a slight hum even when the lights are unplugged. Typical physical hum from vibrating laminations. I went ahead and shut off the circuit at the breaker box just to be sure I didn't burn down the building until I could check it out.
Is there any risk, or power consumption, from leaving it powered up?
