sawmill
Member
Hi all, I'm getting closer to finally building my set of music mains. I've settled on the components suggested by Gary at PE after quite a bit of conversation. The box I am going to build is 18 cu. ft. ported for the woofers, mids and a tweeter. My question is; after looking at a lot of diy solutions on the internet, most people are using mdf for the main structure and bracing. In my mind, it would be much stronger to use baltic birch or even marine plywood for the structure as it is so much stronger than mdf. Can anyone comment on why so many people use mdf in lieu of other sheet goods? Rob
My thinking is you'll need lots of bracing or double up on the sheets of mdf to keep the box from flexing or both. I'm also thinking something that gigantic needs to be built in place or have casters mounted on the bottom. Do you have an airplane hanger you need to fill with music
