TriodeLuvr said:
That used to be known as an "economy supply." The center tap produces roughly one-half the voltage of the main output of the bridge. This was fairly common at one time in tube-type communications equipment for powering output tube screens. It's particularly well-suited to tubes like the 6146 and 807 that impose screen voltage limitations that are well below the voltage applied to the plate.
There seems to be some confusion here - My post was describing the HV supply. Your comment and the circled areas on the schematic reference the filament circuit. Two completely different things.So the center tap is at the 6.3v heater string winding and then goes right to the cathodes so how does it get rectified to 12vdc? Its not a huge deal because the voltages are correct I’m just trying to learn something. View attachment 3179869View attachment 3179870
