Um, yep, it is the power switch.. I will try that pending some more advice?I do not have a service manual for this unit so...
Assuming that is actually the power switch...You just need to connect the two terminals with the brown wires and the capacitor together...
Yep, 0.2 ohms when on. There is no question that the power switch (or maybe that cap) is a problem. It was acting up for a while, but now the unit turns on with shorting noises from the power switch, flickering lights, etc. I want to remove the switch from the equation to see if anything down the line has been damaged.A safer way would be with the unit unplugged use an ohmmeter and measure the resistance across those two terminals...It should measure less than 1 ohm with the power switch on and should show an open circuit when the switch is in the off position.
Have you checked any and all of the fuses in the unit?
It has channel switches, loudness, and tone defeat but only their LEDs are wired into to the power switch, far as I can tell.Also just going by your picture it looks as if there is some type of additional switching taking place on that switch assembly.
Yeah, but I was not feeling confident in my ability to identify those. Would you agree with JBLguy's identification of the ones with the heavy brown wires connected?Those are omron microswitches readily available..To by-pass you need to short out the common and normally open contacts.
It will be fine.It won´t blow..Thanks for help & link. I will give this a try in a bit here. One more thing, can I remove that cap (the one between these terminals) for now? I have a feeling it would like to blow..
See your other post about the Omron switch.Did you end up replacing that switch? If so what Omron switch did you use? I am replacing one that I can not find a replacement for.
The whole idea about by-passing a power switch. Is to create and " instant on " condition. In your case. Either find a replacement switch. Or plug your piece into a switchable power strip..Hello I have a Rotel with a instantaneous on power switch that appears to be faulty how do I bypass the switch with three wires one black one gray and one white thank you for your help
