NN, Looks like mine is the oldest one so far, Ser # 100071
Bart, I posted 2 pics:
HERE &
HERE
It's got a label on the end that says "Alps snap switch L 72" and the #'s SDU4P 7v 5 72 appear on the cover plate, one or two of the digits are hard to read and may be incorrect. If you look closely, you'll see the back, heavier duty section separates from the front light duty section. The front section is soldered and screwed to the PC board.
The good news about this design is that if I have to make something else work, the existing front part should maintain the original look and feel, I would just have to make sure the new switch aligns to the protruding section of the front switch.
I'm thinking of a different idea, and would like some opinions on this. The front section of this switch is a DPDT design, however only 1 leg of rear section is in use, the other two pins are connected to blank spots on the pc board. My idea is to use these two contacts to close a relay that would supply power to the two power supply leads. The 2 currently UNused contacts would only be drawing enough current to close the relay, they should be able to handle that with no trouble. This can be done fairly easy, all the wires I need are right there, there is plenty of room to mount a relay AND I can keep the original design by connecting to the existing PC board.
I believe this relay should work fine, it's 10 amp rated, (that would be 10 on each leg?) and the 16.5 uses two 7 amp fuses.
http://www.radioshack.com/product/i...ay&kw=relay&kwCatId=2032058&parentPage=search
Any Thoughts?
