| Section | Label | Actual Value | Power/Voltage (minimum) | Price | Supplier |
| Power Supply | C101A – 1000uF (can 1) Authenicap | 1000uF | | $ 229.20 | CTECH |
| Power Supply | C101B – 40uF (can 1) Authenicap | 40uF | | | CTECH |
| Power Supply | C101C – 20uF (can 1) Authenicap | 20uF | | | CTECH |
| Power Supply | C101D – 20uF (can 1) Authenicap | 20uF | | | CTECH |
| Power Supply | C102A/B/C – 50uF (can 2) Authenicap | 50uF | | | CTECH |
| Power Supply | C103A/B – 1200uF (can 3) CE Distribution Made by Mallory | 1200uF | | | CTECH |
| Power Supply | C104 40uF 200VDC | 47uF | 350V | | CTECH |
| Power Supply | SR1 Diode (1N4007) | | | | CTECH |
| Power Supply | SR2 Diode (1N4007) | | | | CTECH |
| Power Supply | SR3 Full Wave Bridge | | | | CTECH |
| Power Supply | R101 1.0M 1/2W (VISHAY CMF601M0000BEEK 1W 1%) | 1M | 1/2W | $ 1.44 | Digikey |
| Power Supply | R102 1.5K 1/2W (VISHAY CMF601K5000BEBF 1W 0.1%) | 1.5K | 1/2W | $ 1.33 | Digikey |
| Power Supply | R103 1.5K 1/2W (VISHAY CMF601K5000BEBF 1W 0.1%) | 1.5K | 1/2W | $ 1.33 | Digikey |
| Power Supply | R104 1.5K 1/2W (VISHAY CMF601K5000BEBF 1W 0.1%) | 1.5K | 1/2W | $ 1.33 | Digikey |
| Power Supply | R105 2.7K 1/2W (VISHAY CMF202K7000JNEA) | 2.7K | 1/2W | $ 0.79 | Digikey |
| Power Supply | R106 10K 1/2W (VISHAY CMF6010K000FKEB 1W) | 10K | 1/2W | $ 0.65 | Digikey |
| Power Supply | R107 7.5 ohm >=5W (VISHAY CW0057R500JE73) | 7.5 | 5W | $ 1.64 | Digikey |
| Power Supply | R108 7.5 ohm >=5W (VISHAY CW0057R500JE73) | 7.5 | 5W | $ 1.64 | Digikey |
| Power Supply | R109 47 ohm 1W (VISHAY CMF6047R000FKBF) | 47 | 1W | $ 0.71 | Digikey |
| Left Channel Phono | C1 – 39pF (WIMA FKP2J000391D00HSSD) | 39pF | 630V | $ 1.95 | Digikey |
| Left Channel Phono | C3 – 50/3 Replace 50uF with 100uF Spragie Atom TVA series electrolytic 100V or Jupiter Cosmos Series Axial 100uF 100Vdc/50Vdc based on c22 | 50/3 | 16V/50V/100V | $ 5.95 | Partsconnexion |
| Left Channel Phono | C5 – 0.01uF 400V Obbligato 630V Copper Series | 0.01uF | 400V | $ 1.92 | Partsconnexion |
| Left Channel Phono | C7 – 0.22uF 630V | 0.22uF | 630V | $ 6.35 | Partsconnexion |
| Left Channel Phono | C9 – 0.47uF 630V | 0.47uF | 630V | $ 6.35 | Partsconnexion |
| Left Channel Phono | R5 – 330K 2W LN (VISHAY PPC330KW-3JCT-ND) | 330K | 2W | $ 0.72 | Digikey |
| Left Channel Phono | R13 – 1M (VISHAY CMF601M0000BEEK 1W 1%) | 1M | 1W | $ 1.44 | Digikey |
| Left Channel Phono | R15 – 120K 1W (VISHAY CMF60120K00BEBF) | 120K | 1W | $ 1.17 | Digikey |
| Left Channel Phono | R17 - 820 (VISHAY CMF60825R00FHEK) | 820 | 1W | $ 0.43 | Digikey |
| Left Channel Phono | R23 – 330K (VISHAY PPC330KW-3JCT-ND) | 330K | 2W | $ 0.72 | Digikey |
| Left Channel Phono | R25 – 330K (VISHAY PPC330KW-3JCT-ND) | 330K | 2W | $ 0.72 | Digikey |
| Left Channel Phono | R27 – 1M (VISHAY CMF601M0000BEEK 1W 1%) | 1M | 1W | $ 1.44 | Digikey |
| Left Channel Phono | R29 – 47K (VISHAY CMF6047K000BEBF) | 47K | 1W | $ 0.94 | Digikey |
| Left Channel Line | C11 – 39pF (WIMA FKP2J000391D00HSSD) | 39pF | 630V | $ 1.95 | Digikey |
| Left Channel Line | C13 – 0.0068uF (6800pF NICHICON QXT2J682KRPT) | 0.0068uF | 630V | $ 1.30 | Digikey |
| Left Channel Line | C15 – 0.1uF 400V (Nichicon PWS1633100KG) | 0.1uF | 400V | $ 2.85 | Digikey |
| Left Channel Line | C17 – 0.22uF 630V | 0.22uF | 630V | $ 6.35 | Partsconnexion |
| Left Channel Line | C19 – 0.47uF 630V | 0.47uF | 630V | $ 6.35 | Partsconnexion |
| Left Channel Line | C21 – 0.022uF 630V (Nichicon PWS1632220KD) | 0.022uF | 630V | $ 1.76 | Digikey |
| Left Channel Line | C27 – 0.025uF (25000pF) (Affinity For Artifacts EBAY) | 0.025uF | 630V | $ 4.00 | Affinity For Artifacts |
| Left Channel Line | C23 - 0.47uF 630V Mundorf MCAP Classic | 0.47uF | 630V | $ 6.35 | Partsconnexion |
| Right Channel Phono | C2 – 39pF (WIMA FKP2J000391D00HSSD) | 39pF | 630V | $ 1.95 | Digikey |
| Right Channel Phono | C4 – 50/3 Replace 50uF with 100uF Spragie Atom TVA series electrolytic 100V or Jupiter Cosmos Series Axial 100uF 100Vdc/50Vdc based on c22 | 50/3 | 16V/50V/100V | $ 5.95 | Partsconnexion |
| Right Channel Phono | C6 – 0.01uF 400V Obbligato 630V Copper Series | 0.01uF | 400V | $ 1.92 | Partsconnexion |
| Right Channel Phono | C8 – 0.22uF 630V | 0.22uF | 630V | $ 6.35 | Partsconnexion |
| Right Channel Phono | C10 – 0.47uF 630V | 0.47uF | 630V | $ 6.35 | Partsconnexion |
| Right Channel Phono | R6 – 330K 2W LN (VISHAY PPC330KW-3JCT-ND) | 330K | 2W | $ 0.72 | Digikey |
| Right Channel Phono | R14 – 1M (VISHAY CMF601M0000BEEK 1W 1%) | 1M | 1W | $ 1.44 | Digikey |
| Right Channel Phono | R16 – 120K 1W (VISHAY CMF60120K00BEBF) | 120K | 1W | $ 1.17 | Digikey |
| Right Channel Phono | R18 - 820 | 820 | 1W | $ 0.43 | Digikey |
| Right Channel Phono | R24 – 330K (VISHAY PPC330KW-3JCT-ND) | 330K | 2W | $ 0.72 | Digikey |
| Right Channel Phono | R26 – 330K (VISHAY PPC330KW-3JCT-ND) | 330K | 2W | $ 0.72 | Digikey |
| Right Channel Phono | R28 – 1M (VISHAY CMF601M0000BEEK 1W 1%) | 1M | 1W | $ 1.44 | Digikey |
| Right Channel Phono | R30 – 47K (VISHAY CMF6047K000BEBF) | 47K | 1W | $ 0.94 | Digikey |
| Right Channel Line | C12 – 39pF (WIMA FKP2J000391D00HSSD) | 39pF | 630V | $ 1.95 | Digikey |
| Right Channel Line | C14 – 0.0068uF (6800pF NICHICON QXT2J682KRPT) | 0.0068uF | 630V | $ 1.30 | Digikey |
| Right Channel Line | C16 – 0.1uF 400V (Nichicon PWS1633100KG) | 0.1uF | 400V | $ 2.85 | Digikey |
| Right Channel Line | C18 – 0.22uF 630V Mundorf MCAP Classic | 0.22uF | 630V | $ 6.35 | Partsconnexion |
| Right Channel Line | C20 – 0.47uF 630V Mundorf MCAP Classic | 0.47uF | 630V | $ 6.35 | Partsconnexion |
| Right Channel Line | C22 – 0.022uF 630V (Nichicon PWS1632220KD) | 0.022uF | 630V | $ 1.76 | Digikey |
| Right Channel Line | C28 – 0.025uF (25000pF) (Affinity For Artifacts EBAY) | 0.025uF | 630V | $ 4.00 | Affinity For Artifacts |
| Right Channel Line | C24 - 0.47uF 630V Mundorf MCAP Classic | 0.47uF | 630V | $ 6.35 | Partsconnexion |
