Victor
As Serge correctly said, once you get to systems this good, the changes you hear are subtle differences. Once your system gets this good I find any improvement no matter how small exciting. It does take some "critical listening" to hear these differences.
To do some critical listening to hear these differences in an AB test you need to pick out a specific part of the music and concentrate on just that one part. For me I find the easiest things to listen to for this test are cymbals, snare drums and vocal echos. For example on the Diana Krall Live In Paris CD on track 1 the cymbals are well recorded, listen to the tone of that cymbal (does it sound sharp, flat or natural). On the beginning of track 5 listen to the ring of the cymbal (how long is the decay time). On track 2 (50 seconds in) listen to the snare drum played with a brush, listen to the amount of detail there. Compare these small parts of the music and see if you hear any differences.
Now there is the long term listening test. Listen to the system for a few weeks without doing AB tests. Do you find yourself listening to music more or less with the new setup. Often times after listening to a setup for a few weeks that is slightly better, when you go back to the old setup you will hear the difference right away.
I always found the B&W speakers with aluminum dome tweeters to be a little harsh. The C2200 could be doing a good job smoothing out that harshness, and it would not surprise me if you liked your system with the C2200 in it better. Now the B&W diamond tweeters are much smoother and I would expect it to sound much better with the MDA1000 going directly to your amps with the diamond tweeter B&W speakers.
And again as Serge said, if you don't hear any difference great, you just saved yourself $17,000.
