Recapping continued today but it was slow going. A lot of head-scratching about what cap to use, and what size leads, etc.
Top Panel and Input boards
A photo of two YELLOW FG (Nich Fine Gold) caps installed in each of three PCBs below. These boards are DONE with the exception of a ground screw.
Two new Nich Fine Gold caps in each of the three PCBs above.
Power Supply section
Turns out there were FG caps ordered over a week ago, and then I ordered general purpose VZ caps, probably to compare one against the other during installation. With
input from PMs and emails earlier, I decided to go mostly with Find Gold caps in the power supply.
Two FGs in the upper left, and two big 50 Volt VZs in the center are seen below. These are
the larger of the two 4700uF caps. They fit the best based on lead spacing and diameter.. almost a direct drop-in. Not bad!! I seriously doubt Mouser would supply bogus parts.
The larger of the 4700uF caps (50V) were installed due to lead spacing and diameter.
Reverse view
There are two more FGs behind the big 4700's, and a 470uF VZ cap to the extreme left. I tried to install a FG there, but it was too damn big for the pads and holes, etc. No wire gauge drill bits could be found to open up holes today. Will have to order more.
What next
Another
EIGHT interstage NPs will be installed tomorrow. After that, the amp will be re-assembled and tested.
The front panel will have to come off before long.
-Greg
