perryinva
IS it vintage????
This is a great thread for information on substitutes and possible issues on the C33. Let me pay a little forward in case someone down the road reads this and has this issue & contribute a small bit.
I recently came across an annoying fault in one of my fully rebuilt C33s. (All new electrolytics and upgraded opamps in many locations). The left channel would occasionally (but consistently) experience a reduction in clarity and volume, regardless of the source. Investigation showed that regardless of which channel was sent to the Left output, the Left output was the issue, whether through headphones (on board amp) or output to an external amp. This eliminated a lot of possibilities for problem components. The problem was I could never reproduce the problem with the unit open on my bench to trace it out. But it always did it after about an hour of normal playing when installed in a system, closed in its case. Bottom line, it was the muting transistor after the LDR as part of the mute during start, a 132-170. It is practically the last component in the output chain. . I replaced the pair (to match) with P1087 (cross legs 1 & 2 to match the original) and all is great again. Transistor tester showed the left transistor bad/broken and the right as two equal diodes. But the tester shows the 1087 correctly as a JFET.
