Hello everyone, I was doing my project for C33 so good now its quiet. Doesn't power on. When I did power on for the first time after recap, smell came from PC board 045809. 10uf cap.
On the picture of #045809 board taken by Gregory, big cap 10uf 200v placed in opposite way +/- comparing to schematic. Is it right or wrong?
Added my pictures of this board to compare how cap is placed. Also bi-polar cap 10uf 25v was shorted during replacement, causing problem to power on.
Suppose I'm not feeling all that sharp today. C1302 used in the Auto-On board 045809 is across the AC input power relay with a 110 VDC solenoid. The cap seen in the photo is the original cap, and I didn't replace anything on that PCB. Wasn't broke so didn't touch it.
-Gregory
Is it possible to get over-voltage to that power circuit by switching polarity?
Maybe it was a problem for me to get hot R1303 resistor, blown C1302 capacitor, blown fuse AGC 250v 1A, bit smell and failure to power on. Relay was not clicking.
Changed polarity. It works. Thanks.
Another puzzle. On original input board caps C526, C527, C528, C530 were placed with different polarities comparing to schematic. Equalizer board has also puzzles. Caps C721, C722 also show different polarities according to schematic. What is your opinion? Does it need to be replaced?
Gregory, would you say the sound quality of your C33 has improved after your recap? And if it has how so?
Ironically, in one of my C34V pre's, one of the 150 ohm headphone resistors, R1052, bulged and split in the middle. Luckily it's an easy part to replace. The service manual specs them at 1 watt but all four in mine were 1/2 watt.
I would like to make a comment that applies to ME and my C34V's. It may apply to Gregory, it may not. These vintage units would need a recap eventually. I am a retired electrical engineer. I am the kind of person that enjoys looking at the inside of a preamp as much as the outside, gets satisfaction seeing 80+ high quality Nichicon caps sitting perfectly vertically positioned on the circuit boards, with perfect solder cones beneath them, I assure you, when I turn it on, the unit will have dropped 0.5% THD whether it did or not. It was a labor of love and the satisfaction of working on my units was worth it. I should point out I am a perfectionist in some regards but a complete scatter brain compared to Gregory in others. He leaves me in the dust. :yes:Gregory, would you say the sound quality of your C33 has improved after your recap? And if it has how so?
