I have a ca-1000 in beautiful condition that I bought "for parts". Seller claimed that left channel didn't work. I've found and fixed a couple bad solder joints on the input board which seems to have fixed the complete drop-outs of one or both channels. However, a problem remains where at very low levels on the volume dial (0-2) the right channel is 30mV lower than the left channel. If I keep turning it up to > 4 the imbalance switches to the right channel being higher/louder than the left channel. My ears hear this and I can see it on an oscilliscope.
Yesterday I opened it up and cleaned out the relay. I also found a bad solder joint on the volume board plus sprayed the volume pot with D5. However the imbalance persists.
Now, if I turn the balance half a click to the right, things balance out at low-volumes so I could just try to ignore it (though it would irritate me). The problem is that if I turn up the volume while compensating with balance I'd have to remember to rotate balance to the left of center since the imbalance switches sides (which would really irritate me).
So... Any other ideas to check? I saw that avionic suggested to clean out the pre/power switch which I will try. But given that the balance changes with the volume I think the pot is showing it's age. Based on the service manual I think the volume knob is specific to the ca-1000. Does anybody know if it can be found in a cheap/easier to obtain model?
