mbz has them mis-identified. Look at page 17 of the service manual.@mbz i have the pot assembly out and checking resistances. but what i've noticed is that when i turn my volume shaft it turns the back two pots (nearest the wires). and when i turn the balance shaft it turns the teo pots closest to the front of the amp. in your pic above the balance pots are in the back. am i missing something?
Yep my bad, I've got a CA-1000 open on the bench and I still get it wrong... time to give Ak away...@mbz i have the pot assembly out and checking resistances. but what i've noticed is that when i turn my volume shaft it turns the back two pots (nearest the wires). and when i turn the balance shaft it turns the teo pots closest to the front of the amp. in your pic above the balance pots are in the back. am i missing something?
Have you checked for this imbalance when using the ca-1000 as a power amp , separating the pre ??
Yeah, trace at speaker outs is a bit annoying, however it appears to be at a low volume (20mV/div??)
Any inbalance at normal listening level, say volume at 10o'clock position?
Some parts fail intermittent, could explain why you are seeing differeing results, also wiper contact can be affected by oxidation, grit,,, Both halves of the wave are (almost) equally affected. The mute switch has caused me issues on a few CA-1000's however the point of the tests conducted was to identify where the inbalance occurs. If you are happy with the level at the brown wrap wires on the volume board then look elsewhere, eg, probe PRE-OUT RCA's and compare with speaker outs. Also probe the yellow wrap wires on the vol board, these go to the filter board.
Filter board so named since in includes filter switches, it does contain transistors and along with the tone board is part of the pre-amp.Am I right that the filter board is actually the pre "amp"?
The green wrapped wires connect to the PRE-OUT RCA's. If the channels are balanced then need to look forward, ie coupler switch (disassemble and clean). Power amp previously tested ok.and on green it shows my slight difference.
Not good, points to problem earlier on, ie, filter, tone boards or,,,The signal seems to be amplified (unequally) when it leaves on the green board.
Yep, just a simple resistor. Problem is the audio still passes through the switch even with muting off.I expected it to be passive muting.
