Roger Gorke
Well-Known Member
After not doing "the noise" for a couple weeks, it started doing it again. It is only on start up and only in the first min or two after the relay clicks on. It is independent of function and is NOT volume dependent nor affected by auto muting switch, meaning it still does the sound if I turn the volume all the way off. It is in both L and R channels.
This thread sounds like it might be similar to my issue.
https://audiokarma.org/forums/index.php?threads/cr-820-scrunching-noise.993394/
