Good question. I'm away from home so can't check my CA-1000, maybe someone can chime in, measuring resistance between the "C" wire and the -50 wire on each power amp board.What should be the "norm" reading for C to -50?
Yes, you can unsolder leads and remove board from chassis for resistance measurements.Can I do the same (ohms) testing, if I pull all the leads from the main board and remove the board from the chassis?
Trying to do the test is killing the ABCS leads. They keep breaking from turning and twisting the board. This would allow me to also double check all the components and PCB.
Your path for C (mentioned above) is very different from the path illustrated on the image you posted from Friday Feb 11?
Response to question what should be normal C to -50Probably path from C to R615, R614, R613, R605, R603, R604, R606, approx 20Kohms +/-10%.
Paths through TR605 should give OL
Looks a bit strange, depending on meter probe orientation there is a path from TR605c to TR605b then R608/wire C. I don't see a 20.6k resistance. Following from markthefixer may be helpful with transistor testing.Lastest
C and -50V = 21.0 K
RED LINE: B(21K) thru VR603(21.0K) which is set at 00.0, thru R617(21.0K), thru R620(20.6K), thru TR605(00.1) at E, thru R619(0.0) to -50
pure BS, well kinda...47k is not of interest (to me at least), with TR605 removed is the MM current flowing through R615,613,610, TR601s-d,VR602,TR602b-e, R607, R603,4,6.
Keep in mind VR603 is not zero on left ch. Don't see a connection to -50V at CRed or Black on -50 to C =20.4K
FYI
LEFT CHANNEL: Black on -50 to Red to TR605 "collector" pad 18.5K
Red on -50 to Black to TR605 "collector" pad 16.9K
Did you compile a parts list at the completion of your project?
Germanium diodeSD46 Diode, needing a replacement part #
