Cable "burn in"
Status
Not open for further replies.
Some do, but you'll pay for that extra time. A trusted audio dealer will usually allow their repeat customers to try new cables for a while with the option to return. Just like with most new components.
Since I'm not really in the market, I didn't know about any cables specifically but I am not surprised to hear that.
And charging extra only makes sense if extra work is done.
Another aspect of this that I find odd is that things invariably sound better after "burning-in".
It seems to me that any changes that may actually arise have an equal chance of making things sound "worse".
Shhh. You'll upset the true believers.
Which is the part that annoys you most, that someone spends that much on cables? Or that you can't afford to buy them to disprove what they think they hear?
It's all rather amuzing. There is much to be said about a good quality cable. There is much more to be said about a poor quality cable. I think most can recognize a 'bad' cable, particularly one where the connector is shorted or there is insufficient shielding.
Another insite. I had Mono Price, 4/12 wire feeding my LaScala 2s. When I changed to Furutech a36 wire (non burn in). There was a significant sound improvement between the 2 sets of wires. The a36 gave a sense of openness & detail over the MP wire. Now there's no magic shielding with both wires. The only thing that can explain it is, OCC Copper over the OFC. I did put my Amp on MONO & only changed 1 channel to ''A&B'' hear if there was a difference.
Speaker wiring lengths and output voltages are significant factors in cable/wire selection. At 50 watts average output into 8 ohms the wire will be carrying an average of 20 volts AC to the load. Output frequency effects impedance. At lengths over 10 feet the carrier wire becomes a concern. Speaker wire is tyically not shielded. Interconnects for turntables have concerns of a different sort. The law of diminishing returns applies to all.
At least Japanese companies like Oyaide, and Furutech actually invented expensive metal processing techniques (OCC 102SSC) to justify the costs of their cables.
Do you have a source where I can read about their OCC discovery?
I read that OCC was invented in 1986 by Dr. Atsumi Ohno (1926-2017) - a professor at the Chiba Institute of Technology in Japan.
Here's a sciencey paper about OCC and copper for wires in general.
https://mcru.co.uk/wp-content/uploads/2011/05/ohno.pdf
I think Furutech products are well made but they don't seem to understand the science they claim makes their products better. If you read their website you'll find it full of misinformation. Like stating that their NCF products change thermal energy into far infra-red. In fact, far infra-red is used to create thermal energy. If you been in a manufacturing facility or many service garages, you've probably seen the long tubular infra-red heaters. That's how they work- far infra-red is easily absorbed by water (people) and warms the body (thermal energy).
Both companies make wall receptacle cover plates and claim that they improve sound by reducing vibration and EM radiation. They look very nice in the photos I've seen.
I'm not saying anything about these because I've never even seen them but it does make you think about their other products when they make these types of claims.
Unless the properties of electrons have changed since I was in college they will flow down the conductor the same from day 1 to day 10,000. The only thing that might change that is corrosion. The conductors we use in HiFi are not exotic and resistance won’t change through the operating conditions we subject them too. All snake oil to sell more cables in my opinion.
My poor choice of wording, rather than invent, I meant they had invested in the machinery needed for such processes. Yeah their NCF stuff has always been a bit suspect (imo) I was under the impression that it turned emi into infra red? Might be a bad translation?
My point was that they at least have a high level of R&D to justify the expense of their cables, which is more than can be said for some 'boutique' offerings costing ten times as much.
If my cables are made from recycled copper, does it mean they are already burned-in?
really depends on what kind of used copper. Old pennies, the vintage one, pre-82, no they were generally not used for electrical transmission and the electrons would need to be taught to function properly. Now one used to replace one of the old glass screw-in fuses in the home electrical panel would not need to be Burned In as it probably already has some scorch marks on it. Must make up over 74.259% or the mix used to make the wire, though.
Status
