Cable "burn in"
Status
Not open for further replies.
I keeped quite long enough. I don't understand why Cheese , Wine, etc. get better with age. Cars, Boats, Tools etc. also benefit from use. Why can't Cables?
You kept quiet?
Simple answer;
Cheese & Wine undergo chemical changes with aging.
Mechanical items burnish the moving parts together till both become smoother.
Would you now care to explain to me how, exactly, electrons moving through a (presumably) copper wire are gonna change anything either chemically or physically about the composition of said wire?
(Remember, we are talking cables to connect a preamp to an amp, so no amount of power that would cause "annealing" of the wire will be flowing)
Awaiting your response.
PS, this IS a serious question, I would really like to hear how, exactly, time of use is going to improve the sonic quality of a piece of wire............... ;)
Cheese and wine are chemically unstable and reactions take place with other chemicals in the environment they are in. "Improve" is a matter of opinion and time, and over the very long term, no one considers the changes to be improvement.
Cars require that fluids like oil be distributed throughout the engine in order to prevent damage due to friction. If you leave a car sit long enough, the battery will go dead, and oil will drain into the pan, and not be where it is needed when you restart the engine. The oil itself degrades over time, just sitting, as do all rubber components including gaskets, seals, belts, and tires. So starting up and running an engine periodically can help keep it lubricated. Keeping it out of the sun can help keep the tires and door seals from degrading.
A cable is metal with a chemically inert plastic jacket that generally protects the metal from the rest of the environment, though over time "oxygen free copper" probably picks some up from the air and may corrode a bit due to sulfur compounds floating around, neither of which would be considered beneficial by audiophiles, but who knows?
Running audio signals through a cable doesn't cause physical changes in the cable unless you run so much power that you heat the cable significantly (like so hot the jacket would melt). That sort of heat would speed the chemical degradation of the cable, and might interfere with its audible performance. I don't know anyone who does that to their cables.
I used power cords from electric heaters as speaker wires, they seemed to work well, but I can't vouch for whether they had been fully 'burned in' by the heaters they once powered...
I buy power extension cords for wire to my speakers from the Home Depot. The wires are some type of copper.
Cut off the plug and socket and cut the wires to length.
I’m a firm believer that extension wire is as good as any speaker wire that is being sold at several dollars a foot
If you look at "Similar threads" down below, there is a post from 2004 about a Nordost cable burn-in machine...for $1200 back then! OK, hands up, how many of you old timers on the board bought one? :naughty:
Status
