Cable "burn in"
Status
Not open for further replies.
I bought a 3' RCA cable to go from my WiiM Ultra to my preamp.
Can I burn in this cable by running the WiiM playing music with the preamp off?
I assume not but I'm just checking.
Wasn't there a song years ago by this crazy guy called Arthur Brown...
I am the God of HELLFIRE, and I bring you...
FIRE, to burn in the cables...
I think they will BURN....
FIRE, I think you should LEARN....
I'll see them BURN...
You fought hard and saved and earned...
but now your CABLES will BURN...
BURN... they are going to fall apart and BURN...
BURN... BURN...BURN!!!
FIRE... YAHHH-HA, they are GOING TO BURN!!!
I SAID --- BURN ---!!!!
You've been living like a little audiophile...
and now your little world is going to burn!!!
BURN!!!!!.....
:oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops:
P.S... perhaps I have had too much of this beer my husband likes. Steel Reserve, with 8.1% alcohol... I'm on my 3rd beer!! :banana::eek::beerchug:
Hmn.
Fact: There is a physical movement of electrons through the wire as they are pulled of one end of the wire and are replaced with electrons entering the other end. Heating of the wire occurs during this process.
Example: When I do the vacuum cleaning in my apartment (yes, it is true, being retired I am the designated vacuum driver but I swear no alcohol is consumed during this process) and by the time that I am finished and unplug the cord it is quite warm.
Theory: Over the designated 175 hours the wire is being annealed through the repeated application of low grade heat. Fully annealed, aka "dead soft" copper has lower electrical resistance than hardened copper.
Conclusion: Does the Theory pass the Smell Test? Answer: Yes, the theory smells. But it did afford me the chance to consume a half glass of beer.
Next up: I will present my theory that dialectical absorption can explain why capacitors sound better after 60 hours of burn in.
I am still working on op-amps. But I still have 3 cases of beer, 2 liters of rum and a couple bottles of apple Schnaps. Something will come up.
Disclaimer: I really do think that film capacitors and op-amps sound better after 60 hours of use. Also, I really like Bavarian beer and Caribbean rum.
:beerchug:,
(Name withheld to protect the innocent.)
I have found that broken vacuum cleaners set out at the curb have well burned in power cables that make for great speaker wires. A bonus is the round profile of the cable jacket. Very audiophile looking.
I live in a 1940 house with some galvanized water pipes so when I get a drink in the morning I let the water run for 2-3 minutes to get the nasty stuff out. I do the same when turning on my gear- I let the old tired electrons out until the new ones can get lined up again. I think burn-in is the same - it takes awhile for the electrons to get "excited". I don't do any critical listening until things get cleared out. I just setup my Harman Kardon A50K tonight for the first time in a year. I had to let it re-burn-in for at least 10 minutes. (tubes) BTW this Harman Kardon is like a fine wine the more I burn it in the more I like it.
I had forgotten all about that! Thank you!!!
True, I run tube gear, so it does take 10 or more minutes for everything to reach temp. especially the tubes.
3' RCA? How many feet of solid copper 18ga wire in your receiver or amp? 175 hours of burn in required? Wow.
Thanks for the replies.
I just can't wrap my head around the idea that cables need "burn in".
IMO, they don't. Simply a trick to fool your brain as you get used to them. If there is any minuscule difference, one would have to have the most amazing ears and equipment. What can be measured on a scope is rarely perceived by the ear. I would doubt one person out of a thousand people here could hear any difference between speaker cables or interconnects in their system, especially if their ears are older than 25-30 years.
Don't over think it. Keep it simple. Get 4 identical speakers and wire them with these cables to your favorite amp on the A and B selector. Run your favorite source with your favorite music for 175 hours. After 175 hours replace one set of cables with new unused cables. Then A/B compare the two speaker sets where the only difference is the 2 cables. (175 hours is suspiciously close to 1 week.) If someone could report back in a week I would love to hear the results.
Been there, done that ..
You can hear the difference with an old Technics 20wpc receiver and a pair of $20 Kenwood surround speakers ..
Using Canare speaker cables...
And I wouldn't put a switch in the signal path since it could mask the results .. wire each channel differently and use the balance button.
Naysayers are just naysayers unless they've tried it ..
Enjoy the music ..
WBC cables are good quality cables ... I've used many of them ... and they make a variety of cables using differing wire and connectors.
Their sound quality can change over time as the materials used stabilize ...
I can say that I've experienced an improvement with both Canare and Mogami cables.
They will ("burn-in") stabilize as they're used .. short or long time, depends on the individual wires, wire coatings and connector insulation in the cable.
If you do it quickly and still don't like the sonics, you're within the Amazon return window and it's all easy ..
The fact that they will take them back outside the return window is, is I think, a solid guarantee ..
Depending on your listening habits getting to 125 hours of use could take weeks ..
You kept quiet?
Simple answer;
Cheese & Wine undergo chemical changes with aging.
Mechanical items burnish the moving parts together till both become smoother.
Would you now care to explain to me how, exactly, electrons moving through a (presumably) copper wire are gonna change anything either chemically or physically about the composition of said wire?
Awaiting your response.
PS, this IS a serious question, I would really like to hear how, exactly, time of use is going to improve the sonic quality of a piece of wire............... ;)
@init4fun, ''quote''
''chemically or physically'' No. My Don Sachs is connected to my Prima Luna HP with @ the time new Straight wires ''Crescendo 3''. After 8 hrs while playing one of my Factory reel tapes, a friend of my came by for a listening session & while the tape was rolling we both heard the change in the music. The music just opened up! I let the tape play the song out, then rewound the tape to the same song. Played it again & there was no change in the sound. If we didn't hear it ourselves, I wouldn't have believe it.
There can't be a more useless "test", if one tries.
If there is an actuall audible difference, then you have no clue whatsoever about the cause:
- you're comparing left and right stereo signal
- the left or right circuitry of your amp, preamp or whatever is faulty...they sure are not identical, even when new, but there should be no audible difference
- same goes for the loudspeakers
- your left and right ear don't hear identical
- combinations or all of the above.
The rest of the wire may also have a few 10th of an Ohm resistance, but it's spread over a much larger area, so the heat is too, and it doesn't feel as warm as the plug.
Also, the contact between the cord's plug and the wall outlet is not perfect, and it can cause resistance. The more imperfect the contact, the more resistance and the more heat generated, at the plug.
Status
