Cable "burn in"
Status
Not open for further replies.
More questions for the manufacturer: what power level signal is required for euphonic cable burn-in? There must be some minimum required power if the signal is somehow causing physical changes to the cable. What is the maximum power you should apply in order to avoid dysphonic (is that the right word?) changes to the cable? Is there an optimal frequency and waveform to use? How were those derived?
I think I can dance on the head of this pin all day...
Would you now care to explain to me how, exactly, electrons moving through a (presumably) copper wire are gonna change anything either chemically or physically about the composition of said wire?
You are kidding right? You are wanting chemical or physical changes in an electrical circuit. You should be looking for electrical changes.
Since we do not yet know where each electron goes or how the electrons individually move when a signal is applied, we have more to learn before we will be able to explain it. Thinking about it, in a new cable the electrons are circling their respective atom and when an electrical signal is applied, the outer shell electrons start bumping around making the current in the conductor. I can believe that over precisely the return window that these electrons will 1) become freer moving, 2) have a better idea of where they want to go both of which will change the results based on testing equipment we don't even know how to design, yet. Or for the ears which on some people can hear differences others cannot. I have no idea if they can hear cable burn in but I'm not saying it can't be heard by any of the 8.2+ billion people on earth.
Might need to be toad off to cutting edge where naysayers aren't supposed to dis stuff they don't hear, believe in or can't afford.
I buy power extension cords for wire to my speakers from the Home Depot. The wires are some type of copper.
Cut off the plug and socket and cut the wires to length.
I’m a firm believer that extension wire is as good as any speaker wire that is being sold at several dollars a foot
I used to just buy bulk lamp cord off the reel.
There was a write up in one of the stereo rags from the 80's I read that said the red 14 ga hook up wire sold by the foot from RS had 99% oxygen free stranded copper. It was pretty cheap too. I bought some back then. It was kind of a pain to use though. The wire was stiff and I had to use a lot of zip ties to make pairs.
Example: When I do the vacuum cleaning in my apartment (yes, it is true, being retired I am the designated vacuum driver but I swear no alcohol is consumed during this process) and by the time that I am finished and unplug the cord it is quite warm.
The cord is warm because of the point contact resistance where the plug fits into the socket. A few 10ths of an Ohm with several amps running through it will get quite warm. P= i^2*R. A resistance of 0.1 Ohm with 5 amps running through it will have to dissipate 2.5W. That's why the plug gets warm but the rest of the wire doesn't. Heating is occurring at the plug/socket interface because that's where the resistance is. The rest of the wire may also have a few 10th of an Ohm resistance, but it's spread over a much larger area, so the heat is too, and it doesn't feel as warm as the plug.
See: "Conclusion:"
:beerchug:
Yes ... works as long as a signal is flowing thru .. which it usually is whether the preamp is on or off ..
And the sonics of many electronic devices change after they've been exposed to a charged state ..
That could include cables.
Burn-in is probably the wrong word ..
Dielectric stabilization is probably a better description and a provable physics phenomenon ..
The dielectric properties of a material change in the presence of current (charged state) ...
Likely they're good cables since the manufacturer bothered to let you know about the process ..
For a good experiment leave one exposed to current for the recommended time and leave the other in the box ..
Then plug them in and listen to the two channels and see if you can hear a difference between channels ..
If you hear a difference, swap the cables and see if the difference moved ...
Enjoy the Music ..
There are charts that show what gauge power cord is needed by calculating amperage and length of cord. Vacuum manufacturers know no one wants to drag a proper 12 gauge wire across their living rooms. Long thin wire running high amps will get hot and reduce voltage seen at the appliance.
None of that has any effect when its only a 1 volt audio signal running thru a RCA cable. I think the burn in crap stems from manufacturers hoping to buy time so you miss the return window.
You can measure difference in cables with test equipment. Shielding, quality of wire material and jacketing do make differences in the readings you will get. I have a ultra low distortion signal generator that reads .02% with a run of the mill bnc cable BUT using the proper low distortion BNC cable it measures down to the .002% threshold of my distortion analyzer. The cheap BNC cable can never be burnt in to reduce its distortion figures.
Electrolytic caps need a short time to form. Any piece of equipment needs a few minutes to settle in, down, whatever you want to call it. But I think it's more of a case of getting burned paying for expensive cables that need burn in time. :biggrin:
I am curious though what brand of cables came with those instructions. :idea:
You mean they don't? Oh, man. I just paid a guy to rewire all the lamps in my house with vintage wire.
I hope he used NOS wire. After many decades of "burn-in", the wires become "burnt-out" and we all know what happens then. This applies particularly to cloth wrapped wires which become leaky with the "luminescent positronium" elements evaporating. This is the source of much of the sparkle in the air in older houses, often referred to as dust motes.
You kept quiet?
Simple answer;
Cheese & Wine undergo chemical changes with aging.
Mechanical items burnish the moving parts together till both become smoother.
Awaiting your response.
PS, this IS a serious question, I would really like to hear how, exactly, time of use is going to improve the sonic quality of a piece of wire............... ;)
Don't over think it. Keep it simple. Get 4 identical speakers and wire them with these cables to your favorite amp on the A and B selector. Run your favorite source with your favorite music for 175 hours. After 175 hours replace one set of cables with new unused cables. Then A/B compare the two speaker sets where the only difference is the 2 cables. (175 hours is suspiciously close to 1 week.) If someone could report back in a week I would love to hear the results.
https://www.amazon.com/s?k=WORLDS+BEST+CABLES&i=industrial&crid=35MAH2JCBP1BV&sprefix=worlds+best+cables,industrial,123&ref=nb_sb_noss_1
See next to his finger, 1st. post.
I live in a 1940 house with some galvanized water pipes so when I get a drink in the morning I let the water run for 2-3 minutes to get the nasty stuff out. I do the same when turning on my gear- I let the old tired electrons out until the new ones can get lined up again. I think burn-in is the same - it takes awhile for the electrons to get "excited". I don't do any critical listening until things get cleared out. I just setup my Harman Kardon A50K tonight for the first time in a year. I had to let it re-burn-in for at least 10 minutes. (tubes) BTW this Harman Kardon is like a fine wine the more I burn it in the more I like it.
I had forgotten all about that! Thank you!!!
Status
