Cable "burn in"
Status
Not open for further replies.
Wasn't there a song years ago by this crazy guy called Arthur Brown...
I am the God of HELLFIRE, and I bring you...
FIRE, to burn in the cables...
I think they will BURN....
FIRE, I think you should LEARN....
I'll see them BURN...
You fought hard and saved and earned...
but now your CABLES will BURN...
BURN... they are going to fall apart and BURN...
BURN... BURN...BURN!!!
FIRE... YAHHH-HA, they are GOING TO BURN!!!
I SAID --- BURN ---!!!!
You've been living like a little audiophile...
and now your little world is going to burn!!!
BURN!!!!!.....
:oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops:
P.S... perhaps I have had too much of this beer my husband likes. Steel Reserve, with 8.1% alcohol... I'm on my 3rd beer!! :banana::eek::beerchug:
A guy in school LOVED that song. He'd always be singing it between classes.
Arthur Brown. Right? :)
I have found that broken vacuum cleaners set out at the curb have well burned in power cables that make for great speaker wires. A bonus is the round profile of the cable jacket. Very audiophile looking.
And they come with a convenient molded clip for excess lengths!
I just try not to get lost in the weeds when it comes to interconnect's and
Speaker wire. Zip cord for speaker wire, and decent quality cables at a reasonable price. There us way too many other things to worry about.
However, there's this little voice in the back of your mind. "What about the interconnects? What about the cables? Am I doing all that can be done for the system?"
Not that manufacturers are exploiting that little voice or anything like that.
Right?
Right?
I whipped that little voice into silence a few years ago. :biggrin: Try it, it's a great stress reliever. :whip:
Be alert! Just when you thought you had it whipped...
Up next: Shorter wires have less resistance. Unless you trim your connects to the absolute shortest length your system is not optimal!
I'm a retired HD master mechanic of 49 years. I've never heard the term burn-in except in valves or bulbs. I've also read many time to NEVER use a
brand new electric motor for more than a few seconds-minutes at a time. My pasta maker is pretty clear, just like a new vacuum cleaner. Don't just
turn them on and let them run hard for prolonged periods of time when they are brand new.
You let things BREAK-IN just like it says in every owners manual of every car/truck/piece of equipment.
What is break-in? It's pretty simple and you can use a point and shoot thermal gun and see for yourself.
I've ran many test many times and noticed one thing about every new engine, hydraulic pump, electric motors and just about anything that moves.
The temperature usually goes DOWN a few degrees over a short period of time. Most equipment is 100 hours or so. Rings seat, paddles seat, gears
mesh, clutch disk/separator plates/pressure plates seat, brakes work better, transmissions shift smoother, windows role up easier, tires hold the road
better, noisy thing either get louder or they quiet down, BUT things do change. Over a period of 5 minutes or up to 200 hundred hours or so. BUT
the average is around 100 hours for ALL heavy equipment. Then they say drain the boxed and replenish with new oil. They usually want an oil sample
from the drained boxes, hydraulic oil and engine oil.
Why do they want samples of oils? It establishes a base line for where they started and where they are going. If you see antifreeze in oil samples at
100 hours and none at 350 (total) it could have been a slight goof when commissioning the unit or a liner/oil cooler etc, and the sealers did their job.
All the in frames I've ever done I always add coolant sealers for warn mating areas that weren't resurfaced. It was just common practice in every
dealership I worked at from Cat, John Deere, Cummins, Detroit, Deutz, Ford, International, Studebaker, AMC, Rambler and a few more places I've
worked.
I've also notice that once these changes slow down considerably, a normal "service life" begins. Oil sample should show a very distinct drop in all
the different metals in the system. If you see increases, get ready your going to have a problem down the road. It's just the nature of the beast and
a matter of time.
Cables I know one thing, they settle over a short period of time. 10 minutes to a couple of days. I also use contact enhancers on a lot of the electrical
contacts depending on what they do. I know some of the materials used, SEAL the contact surfaces from environmental contact. I know in electrical
boxes they use contact enhancers especially where aluminum is involved, it's actually a requirement via contract in new home construction in my area.
I'm not sure I hear a difference as much as I see with a thermal gun, the DROP in temperature of most electrical components especially valve gear after
they have been recapped, resistors, wire swaps, transformers after being reworked, new valves burning-in switches seating, etc.
They usually run a few degrees cooler. Caps form, resistors cook off the sealer, the wax melts so to speak and the heat transfers easier.
The rebuilt smell goes away over a few hours.
Do they sound different, I don't know but my ears settle and get used to the newer sound. Never let it be said you have poor hearing memory unless you
truly do. Great example is if a person calls and you recognize their voice BUT haven't talked to them in years. No one else on earth sound like that person.
Why is that?
I worked as a kid for a machine shop and we repaired turn tables for a local Russco/Sparta/QRK dealer that services a lot of the TT at the
AM/FM radio stations at the time. They rewired tonearms for a lot of people. They were located in El Grove CA. They had a woody tonearm that was
and still is pretty popular even though they went out of business in the 1990 (?). They left the tone arm wire which was either silver or copper on a trickle
charger 24/7/365 and you always pulled the wire from the spool (after the wire was inspected under a scope to see how the wire went through the die)
and kept the wires running the same direction except for the ground wire, it was reversed.
I know several tonearms came to them for rewire brand-new out of the box. I never bothered to ask why. I just did the work, I never really thought about it.
BUT I still looked at wire under a scope until the day I quit building 25-100K wire looms for heavy equipment in 2000 or so. I guess it's pride in being constantly
right or constantly wrong, but one thing for sure the writing on the wire all went the same way for the most part, unless it was a ground and it went the
other way. :) BTW it was the first time I saw directional fuses, in digital feed wires. Reverse the fuse LOL they will blow. They have a diagram on the fuse
that shows a diode in the fuse mix. Install a 12VDC breaker in backwards. See how long it last.
People say cables don't have a sound. I've noticed one place they do. SE RCAs from the tonearm to the preamp. Screw up that cable and tell me it
doesn't change the sound. AC, speaker interconnects, XLRs, 10 minutes and let the enhancer dry or seep into the cracks. I've never been able to
hear the difference.
So for the record things burn up, things blow up, but only one thing burns-in. Light bulbs and everything else breaks-in to start a normal service life.
Regards
worked.
a matter of time.
Why is that?
Regards
I'm glad we got that straightened out.
I had a vacuum that had a 17gauge cord in it. Seems the companies selling a lot of vacuums can specify the correct wire gauge and get thousands of those cables sent to the factory. They used 17 gauge because I don't know if 18Ga would have handled the load as the cord for this vacuum got very warm while in use for a period of time. It was a well burned in cable.
BURN!!!!!.....
As required, as, Required.
There can't be a more useless "test", if one tries.
If there is an actuall audible difference, then you have no clue whatsoever about the cause:
- you're comparing left and right stereo signal
- the left or right circuitry of your amp, preamp or whatever is faulty...they sure are not identical, even when new, but there should be no audible difference
- same goes for the loudspeakers
- your left and right ear don't hear identical
- combinations or all of the above.
Some things are obvious aren't they ..
But if you swap cables L-R and the difference moves then what's the obvious conclusion ??
That everyone who hears a difference caused by cables is mistaken ??
Or that perhaps the cables are causing an audible difference ??
Enjoy the Music ..
And at least use professional quality interconnects ...
@Ted_E_Boy is on the right path ..
Been there, done that ..
You can hear the difference with an old Technics 20wpc receiver and a pair of $20 Kenwood surround speakers ..
Using Canare speaker cables...
And I wouldn't put a switch in the signal path since it could mask the results .. wire each channel differently and use the balance button.
Naysayers are just naysayers unless they've tried it ..
Enjoy the music ..
Give me the double blind test results.
Will anything bad happen if I use unprofessional interconnects?
Enjoy the Music ..
Let's cut to the chase. Feed a high frequency test signal into the source device and capture the output signal on your oscilloscope. If you have a distortion analyzer, that output would be fantastic in addition. An FFT is another good piece of output.
First test with 'non-professional' interconnects, Do the second test with 'professional' interconnects. Compare the 2 outputs and post the differences. Someone should buy a new set of 'professional' interconnects and perform the same tests before and after burn-in. For those more adventurous, perform the test before and after burning one.
Status
