Cable "burn in"
Status
Not open for further replies.
Most of mine is now new. If I would of sold the old stuff it replaced I would be ahead thousands.
As it is I have a couple thousand into it and the SQ is better :rockon:
This. I scratch my head sometimes, especially with speakers. Guys want recommendations but they seem to only want ideas for speakers that are 30-50 years old and dismiss new designs, even though I suspect they've never heard any. Nothing wrong with old speakers and there are some good ones but once you hear a nice, new design, it's often like a veil has been lifted. You don't necessarily need a big box to get some really good, accurate, tight sound. Oh well.
First test with 'non-professional' interconnects, Do the second test with 'professional' interconnects. Compare the 2 outputs and post the differences. Someone should buy a new set of 'professional' interconnects and perform the same tests before and after burn-in. For those more adventurous, perform the test before and after burning one.
I would think that "professional" means balanced. No?
But if you swap cables L-R and the difference moves then what's the obvious conclusion ??
Well that means that the orchestra is set up wrong. Should hear the channel differences unless one is using the mono button, if provided.
Can't get folks to change their mind on cables in this forum.
Wasn't there a song years ago by this crazy guy called Arthur Brown...
I am the God of HELLFIRE, and I bring you...
FIRE, to burn in the cables...
I think they will BURN....
FIRE, I think you should LEARN....
I'll see them BURN...
You fought hard and saved and earned...
but now your CABLES will BURN...
BURN... they are going to fall apart and BURN...
BURN... BURN...BURN!!!
FIRE... YAHHH-HA, they are GOING TO BURN!!!
I SAID --- BURN ---!!!!
You've been living like a little audiophile...
and now your little world is going to burn!!!
BURN!!!!!.....
:oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops:
P.S... perhaps I have had too much of this beer my husband likes. Steel Reserve, with 8.1% alcohol... I'm on my 3rd beer!! :banana::eek::beerchug:
Been there, done that- here on AK in the past. Next day, I get blown up with notifications on what the hell thread was that? What subject? I go in for it just to see what I was up to. Usually find out that I quit when I couldn't type on this junk foan anymore & find out how big a boob I was when " in the state" of ramblin' on. You done well, considering your level of " cranial enhancement", keep it up!:rockon::beerchug:
Well that means that the orchestra is set up wrong. Should here the channel differences unless one is using the mono button, if provided.
I wouldn't find that disappointing.
You share what you can & folks take what they want from it.
That makes it pretty much like every conversation of consequence I've ever participated in.
I used em once and it took out an amp. The cable had a short between hot and ground.
I think thats called a manufacturing defect.
I doubt any cables regardless of cost or provenance is designed to short out.
Bought interconnects for my TT off Azon & they came the notice below.
I think its pretty straight up of WBC to cover the return after burn in if you don't like the cables.
Regardless, I sure hope my TT doesn't sound like crap for the next 175 hours tho. That would defeat the purpose of new cables.
175 hours would be almost 60 3 hr listening sessions. If I'm busy, that could be the better part of a year w **** TT playback!
Hi. And hello from the UK.
I very recently bought a very nice mint condition Moonriver Audio 404 reference Amplifier in perfect condition and a little under half price.
It was a private sale - not from a business.
But the seller turned out to be a high end accessories distributor. Including cables. Very expensive cables.
In the eBay description he said that he would include cables… that was a pair of RCAs
And when he rang me to discuss delivery of the Amp at one point in the conversation he asked me what speaker cables I was using- I told him, cables I bought circa 1990. Not quite bargain basement, but only a small step or two up.
His reply was “we can do better than that” and asked me about length - told him. And connection type? I’ve always used normal banana.
He said… and said it like it was the most normal thing in the world. “No problem, I’ll put them on the burn-in machine. They’ll have about 72 hours, which isn’t ideal but you’ll hear them improve further over a few days.
I wasn’t about to display my ignorance so I just said thank you. Later after the call ended I was sent this photo which shows the speaker cables plugged in.
I’m pretty much on the fence about this. A ‘before and after’ is obviously not possible.
But the seller seemed to think it was both - very important and so, entirely normal and expected.
A short makes it 'unprofessional'? Where did you get said cable and how much did you pay for it?
A short, as mentioned by Bob, makes the cable off grade product that should not have been sold. I got em cheap as I worked at the store. They were TEAC cables, dual 6-footer, one channel was shorted, I believe. Early venture into better than the cables that came with gear. Chris fixed up the amp just fine, still using it at times.
As he should having made the investment for the burner. Most here won’t buy cartridges for that much money and with those it is easy to tell if they sound better.
Seems reasonable as it’s fairly easy to make a direct comparison. I’m not sure any home audio/hifi person would ever do the same with cables. You wouldn’t normally order 2 sets of an identical cable. One treated the other not and perform a compare and contrast. Magazines might do that. But I’ve never seen such an article. In fact, up to the moment it was mentioned I don’t think I had ever heard of this process before.
This whole thread is making me feel better about the gaslighting I went through at a Nordost cable demo.
There I am, the only person below the age of 60 in a decent size room in front of a 100k Mac system with 50k b&w speakers. We are tolk that this singular power cable, plugged into God's most detailed preamp with completely change the sound of this music in a way you have never heard. Throughout the demo I heard the same song about 10 times. It sounded the same 10 times. But apparently the gentleman with hearing aids could hear extra clarity, deeper bass and a wider sound stage. I
They also went on to talk about how you need to isolate speakers cables from RF noise, and how cables need to be burned in a directional manner for proper sound "flow". Also they suggested that specific RCA cables they sell are directional.
Alas, but who am I but a man with trash taste in music and an untrained ear for the finer things in life.
Nailed it. It's absolute folly.
I've done it and heard the difference ... directly compared.
I've also sent back a pair that I didn't like the sound of when new only to find out down the road that I liked them after they had been in use for a while ..
It can make a difference for the same reasons that topology, wire coating, and conductor qualities make audible differences in cables...
The answers to why it might happen are in physic's Charge and Field Theories ..
A professional audio cable is one that was designed and engineered to propagate an audio signal not just to light a lamp ...
Here's a quote from Mogami's current catalog intro ..
"Most of the products listed in this brochure are centered around the professional audio, video and digital interface market such as recording studios, broadcast stations, theatres, halls etc. The basic design idea puts importance on sound quality for audio applications and on economy for other applications. There are some items which are available only from MOGAMI, and a common design idea through the whole line lies in the flexibility of the cable, considering handiness and efficiency for wiring and installation."
That everyone who hears a difference caused by cables is mistaken ??
Or that perhaps the cables are causing an audible difference ??
You can't be the tester and testee in a sighted test. If you let somebody else swap cables (randomly) and match volume each time you should identify cables 20/20, if there is an audible difference in your hearing range.
Making an extraordinary claim and proving it are two different things. I have no reason to not beleive you when you claim you hear a difference. When you claim you CAN hear a difference, which implies there actualy is one in the audible range of a human, anecdotes won't cut it.
As this thread is about burn-in, time is your enemy at conducting tests with phisically swapping/comparing cables - one has gone through the "mandatory" 175 hours and the other keeps adding them up, whereby you have absolutely no clue about the order of magnitude and/or behaviour of the alleged changes with time. Linear? Exponential? Coming through in the last hour?...
A reasonable test most of us can perform:
- pick a couple of songs you know well...from CDs (or digital files)...no analog media like records, tape, cassettes...!
- connect CD player with a virgin cable to computer and record with, say, Audacity
- do the same with the same cable when it's burnt in
- trim the recordings to exact same start, so switching between them occurs in the same spot in time (it makes comparisons easier)
- export the recordings in two-channel mono or go with just one channel (not so pleasant with headphones)
- ABX the recordings in, say, foobar2000, preferably with headphones
- take your time and test when you feel to...no pressure.
You can make the recordings available for others to have a go at. If you passed the test, the burn-in procedure is, more than likely, the cause. If you failed, you're left clueless - if there is a difference, your hearing might not be up to it...or your gear - although your claim says otherwise, actually undermining the whole uber-ultra-highend-resolution-price industry.
You can hear the difference with an old Technics 20wpc receiver and a pair of $20 Kenwood surround speakers ..
Besides speakers, you can perform the tests easily for just about anything in the audio chain you think impacts the sound.
They don't claim you have to listen to it for the burn in to take place. Take a player of some kind (I see you have a CD player), connect it with the cables to be burnt in to your preamp and hit play in loop...or must there also be an power amplifier present...and speakers working...or headphones?
Can I burn in this cable by running the WiiM playing music with the preamp off?
I'm going to swim against the tide and make an attempt to answer the question that the OP actually asked. (Yes, radical idea, I know.)
If you believe that cable burn-in is absolute nonsense it will make no difference if the preamp is turned on or off because there will be no burn-in either way.
If you believe cable burn-in is a genuine phenomenon it may make a difference if the preamp is turned on because the preamp's input impedance is affected by negative feedback. Negative feedback not only sets the gain, reduces distortion and flattens the frequency response - it also lowers the output impedance and raises the input impedance. Since the preamp's input impedance determines how much current will flow in the cable, turning it off (and lowering the input impedance) will increase the current flow.
So, if you're a believer, I'd recommend connecting the cable to the preamp but leave the preamp turned off.
Status
