Yamaha5000
Never settle for 2nd best
All that credit goes to jayfree.
Thank you and I agree with you 100%This was a godsend from Mr jayfree.
OK scouring the thread one more time I see this as the TO-220 dual rectifier "updates"? Yes?Be great to modify circuit board to accept
Onsemi...
MUR1620CTRG and a MUR1620CTG in place of the OEM dual common anode and dual common cathode rectifiers.
Yes, that is correct.OK last question for today....can someone please verify i have the correct assumption on the dual cathode and dual anode?
D802 (SS-7) Dual common cathode 863-MUR1620CTG D803 (SS-7R) Dual common anode 863-MUR1620CTRG
Hi @jayfree , I've built one of these using your awesome PCB (thanks!)...have checked what the voltages are that you get from the Left and Right pins on the terminal strip (NB+ and NB- on the schematics)? These should be about -40v and +40v (according to schemos....depending on PCB version), but I'm getting -60v and +60v (same as B+ and B- values)....I've double checked polarities and desoldered and tested all components. The only diff is for the diode arrays, I used SDURF3040CT/SDURF3040CTR. Going into troubleshooting mode, but any input would appreciated. thx!Past the smoke test. View attachment 1997570
Thanks. i kept all the orig resistors except for one since they were w/in 1% tolerance...that blew me away. But, to be sure, i'll swap new ones in for all of them. Thanks for confirming the values you got on J3. If the resistor values doesn't change the values, it's likely that the target values of +/-40v on +/-NB are taken under load with the full circuit active.The resistor should be identical pairs, but yours look different. Check those values against the schematic.
Also I measured my unit with both my boards install and running and I thought I got like 42 volts.
Thanks. I may be confused still. Take TR702 for example. In the Yamaha schematic, it's a 2sb544 which has a pinout of 1=b, 2=c, 3=e. Now compare that to your schematic where the pinout of TR702 is 1=e, 2=c, 3=b. They don't match. I guess I could go through and compare both schematics to ensure the transistors i'm using match the orientation of the pinouts in your schematic, but it would just a lot quicker to see the list of transistors you used. Would you mind sharing that?I designed my pcb's from the factory schematic to be a complete new replacement. I never considered using parts from the original, sorry I can't help with that.
This is perfect. Thank-you!!!!Not a problem, see attached(zipped excel file).
Edit: Added the whole BOM.
JP
