Usually the higher values are used closest to the rectifier. Two reasons: Larger caps can take more ripple current, and the lower current used in following stages can be filtered well with a larger resistor and smaller cap. That said, they'd have used larger values if they had been available at the same cost...
For what it's worth, the Calbest 7615 was a mono amp with the same tubes, schematic attached. Odd that the Stereo version also has the "Rolloff" EQ switch as RIAA was standard for stereo LPs.
