I need to replace the 2SC1583 NPN dual junction transistors used on the driver boards of a Sherwood S9910 receiver. I want to use a pair of KSC1845 transistors. These transistors are rated at half the collector current of the 2SC1583 so I want to verify they are suitable replacements.
Looking at the schematic the current flow appears to go from a 58V source through a pair of 3k resistors (R603/604) to the collectors of the dual junction transistor, On the emitter side it passes through a 10k resistor (R605) then to the collector of TR602 and through the emitter to a 1.2k resistor (R606) and to ground.
Looking at a single junction of the 2SC1583, the total circuit resistance is 14.2k which calculates to a little over 4mA. The driver board schematic is attached. Am I looking at this correctly?
