merlynski
Curmudgeon Electronicist
Suggest solder two wires on a track to check, run low voltage high current (1 Amp or so) through the traces, and measure remaining voltage over the tracks, I know it is time consuming doing all tracks.
Maybe even bend the board a little and see if voltage goes up (or the trace burns).
One day I found a problem such way. Of course, best to be done with an empty circuit card for components
(of course, only to be done if desparate....)
That reminds me of a troubleshooting technique I used years ago for finding shorted traces. I would run enough current through them to warm them up, then pour Freon TF (flux cleaning solvent) on the board and follow the boiling lines of Freon right to the short. Worked great for finding copper whiskers under soldermask that were otherwise invisible. Then they banned Freon . . .
