ashok
Parts list:
- Insulated RCA jacks - 1 pair for output, as many pairs as you need for inputs
- Bugle phono preamp - you can buy a complete kit (board + parts) from one Jack Gallagher on ebay. I do not know if he is still selling the full kit.
- DC PSU is from Marchand. Hagtech offers a PSU too.
- Opamp buffer: Simple one dual opamp IC configured as a unity-gain amplifier. I bought the assembled board from Greg Ball (SKA Audio).
- The 1:1 transformers are from Magnequest. Although other line level transformers should work well. I saw another thread in AK DIY on a tube buffer using the Edcor 10K:10K.
- Pot on the secondary of transformers is a PEC 10K stereo pot.
- Chassis is 12" x 8" x 3" Hammond made of steel. The steel was supremely hard to work with my puny hand drill.
The DC PSU has more than enough capacity to power the Bugle and the buffer.
Grounding on the secondary side of the transformer is not done inside the preamp chassis. The L/R channel grounds on the preamp output are independent.
This preamp is the 4th one I have tried. I started with a NAD 1300 series pre. It was pretty decent, but early-mid 80s vintage.
The next one was a 2C51 tube-based preamp, Gary Kaufman's design. This one had way too much gain, plus I had a stepped-attenuator. A couple of clicks, and it got way too loud.
So, I switched to the Luminous Audio Axiom passive device. This one was really good. It matched well with my system, and I enjoyed it a lot. But soon, I wanted additional inputs and the Axiom comes with only one.
On to the present version. I re-used the 2C51 pre's chassis to build this most recent edition. The sound is very nice. Plenty of detail, but not sterile. Easy to listen to.
