Greetings from Nebraska,
I recently picked up this set of speakers from a Goodwill for $10. I didn't know anything about them, but the included carrying case with cables caught my eye. The label on the subwoofer unit reads - "SoundWorks by Henry Kloss, copyright 1996 Cambridge SoundWorks, 1-800-FOR-HIFI, serial number 54637".
After connecting the speakers and powering up the system, I was pleasantly surprised by their clarity and performance. I didn't know what to expect, but they sound great for their size. Upon further inspection, I was a little confused about their power supply setup. They came with a wall wart style power supply rated for 12v output at 1250ma, brand is "yHi power adapter". There is another separate power cable with Edison plug running directly into the back of the subwoofer unit. I assumed at first that both plugs were required to run the system, but unplugging the additional cable has no observable effect while listening to music. The system continues operating with the same output level, no crackle, no pop, zip.
I wanted to investigate further, so ignoring the large shock hazard stickers on the bottom of the unit, I removed the 4 screws and separated the back plate from the MDF enclosure. Below are my findings:
1) A few pieces of loose hot melt glue.
2) The cardboard port tube detached from the back plate, sitting loose in the bottom chamber of the enclosure. I suspect this was old damage from a previous disassembly.
3) The seemingly unnecessary power cord leading to a small circuit board, completely disconnected from the main amp unit and just sitting loose inside the enclosure.
This small circuit board has electrical tape wrapped around it and seems to serve no purpose. Any components on the board have been desoldered and removed, leaving only bare traces. On one end of the board are the power cable ends soldered to AC traces. On the other end sits a small two prong connecter, which corresponds to a cable leading inside the amp module. The space on the board where some component used to live has an "AUTO TEST" stamped on the surface, and the numbers 4144247523.
My plan is to glue the port tube back in place and reassemble the unit. Can anyone tell me what I've got here? I can't find any documentation to explain the purpose of that small circuit board and additional power cable. Is it possible this is a manufacturer test unit, or modification from the previous owner? Should I attempt to find the missing component and reconnect this to the amp module?
Any insight would be appreciated.
Thank you!!
Thank you!!
