desertrat748
There are several reports about the under $100, ultra-compact SMSL SU-1 being a fantastic audio bargain. After reading/watching a few online reviews, I purchased a couple of them to try out with the intention of modifying one to see if any improvements over the stock unit were possible. I am happy to report that the SU-1 responds extremely well to modifications and has very much exceeded my expectation as to what is possible for a budget DAC. Summarized briefly, to get the SU-1 to sound at home in even a multi-thousand dollar stereo system, you'll need to:
First off, it should be noted that in stock form, the SMSL SU-1 is pleasant sounding device, albeit somewhat lacking in refinement and tonal richness. It features a cutting edge and very interesting Asahi Kasei Microdevices AK4493SEQ 32-bit, 2-channel chip. This DAC chip is part of AKM’s new and well-regarded Velvet Sound brand and sits one step below the flagship AK4499EX. Whether due to its implementation or the AK4493SEQ DAC itself, the SU-1 doesn’t have the pronounced digital glare of many modern DACs. Removing the 4 machine screws on the back panel and taking off the top of the chassis reveals an inexpensively built but rather stout SMT-based board that features either an OPA1612 or LME49720 output opamp depending on production run. Both opamps are generally well-liked and made by TI.
- Power it using a high quality 5VDC linear, regulated power supply
- Upgrade the onboard opamp to a Nisshinbo Micro Devices MUSES02
Now the SU-1 does not come with a power supply when purchased new. Those of you who might have read my Hagerman Bugle modification thread know I’m a fan of high quality, linear, regulated power supplies. Of course, I am not the first person to suggest this as an upgrade, but I can report that the SU-1 responds beautifully to being run on good quality power. I am presently using an Elenco XP-100 Deluxe Battery Eliminator, but any good 5VDC, 1A or greater linear regulated supply should produce great results. I found these outperform good quality, inexpensive switch-mode power supplies (like the Apple 20W USB-C power adapter) by a fair degree with the SU-1. The XP-100 also (surprisingly) outperforms my portable USB rechargeable power bank. While the SU-1’s output is very quiet using batteries, it lacks the drive and dynamics that are present with the XP-100. Also the XP-100 has sufficiently low noise to not adversely affect playback. It should be known that many DC power supplies use a 5.5 x 2.1mm plug, so in this case a DC 5521 female to USB Type C male plug adapter cable is needed: https://www.amazon.com/dp/B0CR4B1YM7?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_10&th=1
The next modification involves removing the onboard SMD opamp and installing an 8-pin DIP to SOIC adapter like the one available at Cimarron Technology: DIP-8 Adapter – BrownDog 201202 – Cimarron Technology. This is a slightly tricky procedure made easier by purchasing a hot air rework soldering station. If the adapter from Cimarron Technology is ordered with a DIP socket installed, a wide variety of opamps can be installed and tested for sonic compatibility with the SU-1. To that end and after many listening sessions with several different opamps, I am quite impressed with how the SU-1 sounds with a Nisshinbo Micro Devices MUSES02 opamp: extremely smooth, highly detailed, and with a magnificent rendering of voices. Best of all, there is virtually no digital glare, to the point where I sometimes forget I am listening to a digital source.
If you happen to be in the market for a new DAC and are handy with soldering SMDs, consider purchasing the SU-1 and performing the above mods. Also if you do, let us know how it goes. The SU-1 pairing with the MUSES02 opamp is so good you may find it to be your new favorite DAC. At present, I am using both the coaxial and optical inputs of my DAC (slightly preferring the coaxial) and as time permits I will start working on using the USB input. At minimum, this will require the use of a split cable that has a line for a separate DC input similar to the Ghent Audio U22 cable, but with a USB C connector. ((U22) Type-A to Type-B Cable with DC-Input)
If you require a remote, the SMSL C100 is virtually the same DAC as the SU-1 but with a remote. Performing the same upgrades yields similar and substantial sonic benefits. Comparing the two, I find the modded SU-1 sounds a touch better, but the convenience of a remote may offset that small benefit. Lastly, due to the number of counterfeits, I purchased my MUSES02 directly from Mouser Electronics and would recommend anyone interested to make sure they are buying opamps from a reputable dealer or they might not get the same benefit described here.
I would like to send a huge thanks to @desertrat748 and @knotscott for testing out the different variations of the SU-1 and providing their extremely valuable feedback. I’m sure they will be active in replies to offer their long term testing opinions. Thanks for reading!!
Just wanted to say that it’s just mind blowing how great this little DAC sounds. How nice it is to effortlessly obtain Uber enjoyment w streaming or CD. And I don’t even have to flip the album over or clean the record! One of the best upgrades I’ve ever made. And dirt cheap! Thanks Oranda. You made my day better!
