Did we ever resolve if it takes standard headshells? If so, they enable adjustment. Many have Azimuth too. Monk can also play with h'shells of differing mass.
Nat is correct, their is no way to adjust the cart. It is set.
Can you align cartridges in the headshell? My memory is that you have two internally threaded posts and if the dimensions of the cartridge work with where the posts are, you are good. If not, you don't have any recourse. With a conical stylus, it may not matter. With a line contact, it certainly will.
Again, I don't think you should go by the conversion numbers here since we have resonance numbers.
Hi Kent - not sure what you mean by the 540 being too low in mass.
They both weigh about the same
Both have the same dynamic compliance rating 10 x 10-6 cm/dyne (100Hz)
- 6.4g -- VM540ML
- 6.1g -- AT-VM95ML
- When converted to an approximate 10Hz rating, both have a compliance of about 18.
@monkboughtlunch Drawing looks almost standard. Can you take a pic of the female, and check if its pins are spring-loaded? Do you have a normal h'shell in the house just to try?
The arm resonance is the biggest issue comparing the two. The AT-VM 95 is more favorable on that dimension. You want to keep the resonance frequency in the 9-11 hertz region due to micro warps on records and static compliance is in the AT-VM 95's favor about what will play nice with your arm. The AT-VM 95 cantilever and suspension is better suited to this application.
What are the resonance numbers?
I posted in this thread. Read my prior posts.
Gotcha. So 9Hz is the resonance with 23 grams effective mass for the AT 95? Do you know what the resonance would be for the AT 540?
What is the difference between static and dynamic compliance? The dynamic of both carts is the same. Only the static is different.
To the first question, I covered that up thread.
To the second question, both numbers would need to match if compliance were the same on both. They aren't. Not in specs or measurements.
Understood. But 7.5hz resonance of the 540 was conducted on a different tonearm with a different effective mass vs the 9Hz reading you got on the 95. Was just curious if anyone has compared resonance of both carts using the same arm and headshell.
I don't need to do that because I can work backwards and figure out what the approximate dynamic compliance @10hz of each cart is. I do this by using the VE resonance calculator along with the known, measured values for resonance and the EM of each arm.
The compliance for the 540ml is likely 20-25.
The compliance for the 95ml is likely 11-15.
TLDR, if you have a medium mass/medium heavy tonearm use the 95ml. The 540ml will work best on light and light-medium tonearms.
What is the estimated resonance for the AT 95 vs the AT 540 in the ROK 320?
Did you measure resonance on the 95ML the same way that hometheaterhifi did when they tested the 540ml?
Here's what HomeTheaterHifi said about their test: "We are using an unorthodox test for the low frequency resonance. This is the resonance excited by groove noise and rumble. We do not measure the resonance with spot frequencies. The spectrum above is typical of the sub-sonic response you will get when you play an LP."
