patient_ot
Did you measure resonance on the 95ML the same way that hometheaterhifi did when they tested the 540ml?
Here's what HomeTheaterHifi said about their test: "We are using an unorthodox test for the low frequency resonance. This is the resonance excited by groove noise and rumble. We do not measure the resonance with spot frequencies. The spectrum above is typical of the sub-sonic response you will get when you play an LP."
I measured with the CBS STR100 test record. I also checked the resonance with a record of actual music. It was the same. This is a common procedure to check resonance. If you want to doubt my test, go ahead. It is not a professional measurement but gets one close enough for actual matching of a cartridge to tonearm.
You can also debate this all day long and not get close to an answer, start multiple threads, yadda yadda yadda.
Or you can buy the damn cart from a place that takes generous returns, set it up in your tonearm, take measurements yourself, and observe performance while playing actual records that contain music. Your call.
Not much else to say here. I doubt anyone else has much better info for you either, since this tonearm is not commonly in use in 2019...
