Blue Shadow
Waiting for Vintage Gear from this century
No wonder multi-amping and eliminating the speaker crossover can make the sound much better.
Sure, that is a worst case scenario - a 12mH coil is a huge value coil.
This would be mostly correct if "louder" equated with "better," but it doesn't....it just means louder. The Maggie 3.5 in question is a beautiful, well-balanced speaker as designed, perhaps lacking only in extreme significant low bass output below 30Hz (a guess..they may have some energy a bit lower). In this instance, of course, if one insisted on substituting in air core inductors, it does mean that you'd need to make sure the DCRs were comparable to the existing solid core inductors or you would, indeed, suffer reduced output from the connected drivers among other things, mesing up the overall system's frequeny response curve.When you want quality sound in the bass, use an air core coil, and use as large a gauge coil as you can, to lower the DCR. ........ so a large gauge helps it play louder than it would with a higher DCR.
Here's an example of magnetic eddy current: wind a wire around a nail, and hook up a battery to the wire, to make a magnet. Pick up some metal object with the magnet - and then disconnect the battery. See how long the object stays put, before it drops off - this is the eddy current. It can be close to a second.
A music signal is reversing polarity many many many times a second. So those magnetic eddy currents are lagging behind constantly, and the louder portions of the signal and going to set up stronger eddy currents, causing greater smearing. This is just how physics works.
And with many speakers, maybe most that aren't from top end manufacturers this will probably yield good results. Magnepan is known to built speakers to a price point and improvements in the crossover can make them sound a good bit better. They wanted folks to be able to afford their speakers not just see them in the showroom and not consider them for purchase.Exactly - rebuilding a crossover with better components - is what I am talking about, too.
Yes, good people.I love my Maggies, I respect the folks at Magnepan.
