Mounting is is probably less practical then adding another speaker stand and using center standing upright . Like my fronts haha .You may not have the latitude to do this, but wall mounting the monitor would free space used by the stand. I like mine tucked just under the monitor.
You are a true Audiophile! Always making the most of what you have. Keep it up. Knowledge is the key. Equipment will come and go but your knowledge will always be there for you.View attachment 1629292 View attachment 1629293 View attachment 1629294 View attachment 1629295 View attachment 1629296 View attachment 1629299 View attachment 1629300 I have this center low but tried to face it upwards with cardboard .
It’s a lcr like set up . Can not bring a mono surround to back because coat tree .
I could not find a better spot for center unless I put it we’re the front speakers are but that could be odd? And it wouldn’t be in center .
dCan you raise your tv and put the speaker on the top shelf?
I think bottom woofer is more for more lower bass top one is more midrange. The middle circular thing is a tweeter looks aluminum with paper cone .I guess ideally for localization, the sound comes through the screen like in a theater. But we mostly have direct viewing displays, so the center speaker should be centered and as close to the bottom or top of the screen as feasible. Tilting the center up to aim toward you will help the sound get better if your center speaker does not have enough lateral dispersion of the sound. It won't help localizing the sound to appear on-screen, as much as moving the center speaker close to the bottom of the screen. Good thing that displays today are no longer sensitive to the magnets in the speakers.
One concern I have about the center speaker in your photo. There are larger two drivers oriented horizontally, with what looks like a silver circular vent with two vanes in it. If this is a bass unit and the silver ring is a vent, then that would not matter much. But if one of the drivers is a bass and the other is a mid-range, you'd get interference effects of the two drivers at the crossover range, which may color your sound there.
Currently I don't use a center speaker. I too have a problem locating a center speaker - no room below the screen. The dialog comes out of the left and the right speakers, and it works fine for me.
ID have to build one of those wooden risers you know the one you set center speaker inside of. You ever made one before ?Put center speaker on top shelf. Put TV on top of center speaker. Put other device down on lower shelf. Clean up random tissues in the pic of the coat tree. Boom, done!
Just put the TV on the horizontal speaker! No custom riser needed! Just do it!ID have to build one of those wooden risers you know the one you set center speaker inside of. You ever made one before ?
If I were to set it horizontally I’d just have 3 front speakers essentially ? Or no
I too would like to reiterate the proper use of too and to. Now, if only there was an example I could show.Note: title should read TOO low, as 2 o's are used to put emphasis on a subject.
I put it as close to the screen as possible.
I can measure the base of tv but I don’t think it will fit on top .Just put the TV on the horizontal speaker! No custom riser needed! Just do it!
It looks like it should balance on top just fine. It's okay if tv base is a little bigger than the speaker. If it makes you feel better place a piece of wood on top of speaker that is closer in size to the tv base.I can measure the base of tv but I don’t think it will fit on top .
Don’t think it’s deep enough.
