Can I get some advice on my first and current set up ever
Great starter system. Much better than many people start with.
Just in case no one has mentioned it*, I'd suggest moving the turntable.
Might be hindering ventilation for the receiver and if you decide to ROCK ON some time you may get feedback issues from the speakers.
*Yes, I know it's been mentioned. It's important enough that I seconded and thirdered what the others said.
Thanks all the responses are invaluable one way or another I've learned so much being here.
So I will definitely be drawing up a better set up with all your comments in mind and put it to work .
Much appreciated
Thanks for your advice and quick reply OMGCat
I very been babying the system as it is my first introduction to records and systems like this in general.
So I haven't played anything past 1/4 volume .
As far as sound to me it has a super warm yet clear sound I am vary impressed with how well things where built back then.
Definitely going to play around with placement and get a better stand for the set up so not to stack on each other. Thanks for the input much appreciated .
Welcome to the dark side.....
The Marantz 2245 / Dynaco A25 combo is a good match. Use both until they fail to meet your taste.
When you replace them store them.
I dont know much as my ears have only heard music not coming from an amp and speaker but from bluetooth speaks and headphone jack to speakers kind of set up .
so to say it dosent sound amazing to my ears right now would be an absolute lie.
Love the warmth.
I suppose it's like chasing the dragon per say
When searching for that perfect setup to achieve that sound you are looking for.
Nice system! How does it sound to you? I like B&O tables and their MI carts.
I’d possibly recommend playing with speaker placement a bit. Also might want to keep an eye on the receiver temp with the TT on top. People have been putting them up there forever and it’s usually not an issue but it’s something to be aware of.
Welcome to AK!
Thanks omgcat
It sounds great for what I'm into right now is not necessarily cranking tunes but more on the musical sounding side of things.
But the B&O is great super easy to use and
I just pulled a record that was really warped like super wavy and it tracked perfect.
So I'm happy so far with the sound I'm getting really fricken happy.
Love the warmth.
It's easy to go through a batch of good vintage speakers only to return to the less than perfect Dynaco A25.
I use the A40XL. Similar sound.
Some of the best speaker stands are the speaker/end tables. I have four of the Realistic Optimus 6 and also Pioneer made similar models as well. The put the tweeters right at ear level when seated. They are a three way speaker as well but I just use them for stands in both my living room and bedroom.
One of the pics shows my Dynaco A25s on the stands.
20181020_125006.jpg 20181020_164438.jpg 20181023_082829.jpg 20181024_134739.jpg 20191004_070908.jpg 20191009_131144.jpg
View attachment 1641725 View attachment 1641726 View attachment 1641727 View attachment 1641728 View attachment 1641729 View attachment 1641730
That's an awesome setup bodyblue
Clever way of using those speakers looks vary cool man.
I'm excited to start tweaking the setup with everyone's suggestion in mind. Not going to lie this is pretty fun and it makes me wonder why it's taken me so long to get into it.
Looking at your system pic, I have a couple of additional suggestions.
Speaker placement: You never want speakers resting on the same surface as your turntable, for reasons of acoustic feedback. Also, your A25 won’t sound their best with the tweeters aimed at your shins. I recommend figuring out which pair you like best and then buying an adequately stout pair of stands that puts the tweeters at ear level. Good stands might run $300+. I’d argue that’s justifiable, but still a good incentive to browse the classified ads.
If you search Google there are actually many plans for DIY speaker stands that will not only look good but will do well. If you have some basic skills. Might be a lot cheaper.
Speakers are always the weakest link and this case that has been confirmed.
So what if any suggestion do you have as far as most efficient speaker that would be drivin by the 2245 in my current setup.
Is their such a speaker in existence.
Looking for suggestion and opinions on set up
In my pictures above you can see my Marantz Imperial 6s........they will sound the best with your Marantz receiver. They are around 93db sensitive.
Moving the small speakers off the stand should give you enough space to set the turntable next to the receiver, which will solve the venting issue, and will probably take care of most vibration issues.
If you recap your speakers ask here first before you just put whatever brand of poly caps in them. I thought I was putting good caps in the two pairs I have and did not like the results and later learned that different brands have different sound qualities. Hopefully you can get some good recommendations from people who have done "your" speakers and liked the results and what brand they used.
My brother is and electrician so this will help and the plethora of information and tutorials out there. Second project
So I've done what I feel like a crazy amount of research before piecing my first ever vintage stereo system.
Take it easy on me as I'm sure there are many things that I have missed but I am all for any recommendations that could be better for my next setup for my basement.
Currently running :
Marantz 2245
Dynaco A25 8 ohms
Bang & olufsen beogram 1602 MMC 20 cart
Paradigm mini mk3 4 ohm
Any feedback good and or bad would be much appreciated
Looks good,
I’d move the bookshelf’s off the same table the turntable is on. Your cart may pick up some feedback form the speakers. Maybe place the TT next to the receiver instead of on top. Isolation is a big part of turntables.
Other than that, enjoy your music :)
