Mr Kantor, if you are curious there is a link to a full schematic on post #19 of this thread. The amp is a Kenwood KA-4006 integrated circa 1974. There is a similar 4558 opamp on the phono pre-amp. It is my understanding that the opamp under discussion in this thread, on the tone board, is in the signal path at all times. That is why it has my interest.
There are no other ICs in this amp.
I would also note that the main amp board does have a speaker protection relay. Your comments about turn on/off thumps make me wonder why the opamp circuit would perform this function when, to my understanding, the speaker relay handles this. But I am here to learn.
Thanks, I missed that!
1- This seals it for me. If the RC under discussion was for supply filtering, one would be needed on the 4558 in the phono section, which is MUCH more sensitive to supply ripple than the tone control is.
2- I only ran through the circuit quickly, so I don't guarantee this, but: oddly, it seems like the relay is Normally Closed, and opens if there is a DC or other error present. It might be closed at turn on. It's a bit hard to tell the way the circuit is labeled, so I might be wrong here.
3- Even with a traditional NO relay, you have a problem at turn off. The relay is slower than the circuit, so you need to give the relay time to open before pops are generated.
4- You could put an NJM4559 in for some improvement in the audio performance, and almost no risk. A 4560 would be a bigger step, but you would be running some risk of oscillation requiring a good scope to track down. A 5532 might work, but could well require adjusting Ri27 and Ri28. This could be done with DVM, no scope. Moving up to boutique chips from National, TI and Analog Devices requires, I think, a good scope and knowledge of the subtleties of finding and taming instabilities.
5- I think it would be a good idea to do the cap first, understand what is going on, and tackle the opamp second. Of course, everyone who rolls opamps has nothing but praise for each step, but I'm a not sure you will get any sonic revelation from this approach. The whole idea of opamps is to take the chip's inherent performance out of the picture. This is done by providing massive gain, most of which can be "thrown away" in order to achieve an almost ideal transfer function.
6- The key to getting DIP and miniDIP sockets with very long legs is to find "wire wrap" sockets.
Have fun!
-k
