Many of us have come to depend on Russian 6P14P-EV tubes for our Dynaco SCA35, Fisher SA-100 and other 6BQ5 based amplifiers, where the output tubes are running close to the voltage and dissipation limits. With the scarcity of 6P14P and its variants at the moment one wonders to what degree and under what operating conditions 6P15P-EV would work satisfactorily in an amp designed for 6BQ5 type tubes. I have a box of them and they seem to be considerably less expensive to buy, even now, than “real” 6P14P-EVs.
If you search the internet for an answer to the question in the thread heading you will find many warnings that 6P15P-EV is a fragile tube, but no direct answers. I have been trying to get at the bottom of the anecdotal: “they are more fragile than …”. I know what the spec sheet says, but the Russian specs are notoriously conservative.
Has anyone reading this actually tried 6P15P-EV in place of 6P14P-EV and experienced failures? Presumably screen failures. If so, was it in UL mode, pentode and at what screen voltage? I have scoured the internet and found many “they are more fragile” references, but have not found any evidence of someone who actually tried it and experienced failure in this swap. If you have experience with this we would love to hear about it. I do know of someone that used 6P15P-EV successfully in his Baby Huey build, but he had variable screen voltage and monitored screen current.
I wanted to determine this for myself, so I’m currently building a Tubelabs SPP (Simple Push-Pull) amp (http://tubelab.com/designs/tubelab-spp/) and adding fixed bias based on Dave Gillespies’ EFB design and variable screen voltage (in pentode mode). I plan to run the 6BQ5 power tubes at 320V (plate to cathode) and screen supply voltage variable between 200V and ~300V, and compare performance under these conditions with 6P15P-EV. I also will connect UL output transformers if the first experiments work well. I will report what I found. Unfortunately I do not have the capability to measure distortion.
