i've returned home with the amp! here is the skinny
Chassis:
Motorola with a few numbers on them
9 "M" 60 i have gathered is the date
HS-890A seems to be the model# for the amplifier
HS-893A or HS-898A (its smudged) for the power supply
tubes:
EZ80/6V4 in the power supply. (British, rectifier?)
12AX7A preamp (USA)
2x ECL82/6BM8 power (British)
Has 3 transformers on the main chassis
Looks like it is 3 channel? the console had a larger woofer between the L and R.
Tone, Balance and Loudness controls. One input.
THE BAD!!
The unit does not power on and no tubes light up. The phonograph did not spin either. Power supply issue? I took it anyway. Free.
I started tracing the voltage from the outlet and got no farther than the fuse. although it looks ok.
I have been given some great advice and will be checking out the dim bulb tester.
happy listening!
this might be ready for the DIY section...
