I would say the tweeters are actually those made for the Smaller Advents with dates from 1973. If you can get one out, measure the magnet. If it is 2.5" square, it is a Smaller Advent tweeter. If it is 3" square, it is a full size Advent tweeter but that date doesn't coincide with when Advent actually was making full size Advent tweeters with green cones. That was in 1975.
The woofers are probably replacements unless the cabinets are from very late in production and even then, it's never been definitively established that Advent used all-metal woofers in any of the original Advent Loudspeakers. They may have. The thing to do would be to remove the woofers and see if there is any remaining residue from Mortite around the woofer opening. If so, they would have originally had Masonite woofers. Even that isn't totally definitive, however, because we never know, Advent could have used Mortite with some of the all-metal woofers before they used the thin foam gaskets.
EDIT: Oops, looking at the photo again, I see a sealer like Mortite was used later so I guess that idea won't work to determine if the woofers are replacements or not..
Audibly, the tweeters, if Smaller Advent tweeters, would be lower in output and the treble from the speaker may sound weak. The all-metal woofers wouldn't matter. They sound the same as the Masonites.
Doug
