Tala Mink
I recently repaired a concept 11.0 with a very badly blown channel.
I had to replace almost every transistor + some resistors and while it does somewhat work there is a large problem with the bias circuit of the amplifier.
The bias pot is extremely touchy at certain points and can jump to the hundreds of millivolts with barely any movement, I can adjust the bias while the unit is on but there is very noticeable distortion on the top of the output no matter what setting it is at
If the bias is above 0 before the unit is powered on, when I do turn it on my bulb will stay lit until I adjust the bias to zero.
I'm 99% sure that this is a transistor issue because the problem is in both channels and the transistors are the only thing that I replaced in both.
Here's what I replaced the transistors with:
501&501 - 2SA872 - didn't change (the offset is adjustable and stable)
503&504 - 2SD668 - KSC3503DS
505 - 2sb649 - didn't change
506 - 2SD400 - KSC2383OTA
507 - 2SB669 - MJE15030
508 - 2SB649 - MJE15031
509&511 - 2SD675 - MJ21196
510&512 - 2SB655 - MJ21195
D503&D504 - VD1221 - 2 1N4148 in series
this isn't something I've encountered before and any help is appreciated
