Studying it I have noticed a couple of errata (I think),
referring to the film capacitors that are in front of the tweeter,
both are marked "MKT 1822" but show different values, 6,8 and 8,2μF respectively.
I think it's because "1822" is referred to the Vishay line and "M9" and "N2" to the model
So the diagram would look like this?
Never hurts to include component details into the schematic. I was just going with the minimum
; Canton ID number and part value. Number for the
8.2µF cap is identified as
2525 on Tony124's board which has that exact part. His assembly is advantaged by small labels to the side of components
as well as screen printed beneath them.
There are ample references to ID no.
1611 for
6.8µF, 100V caps in both foil and electrolytic. But this number "
2" peeking out from under your cap gave me pause from labeling it on the schematic
Canton documents for CT 2000 (posted at
opweb.de) list 6
.8µF, 100V with ID no.
2102, for foil caps
... as well as electrolytic
Though I still hesitate from so labeling the schematic for two reasons
1) Reluctance to assume without verification that the whole screen printed number reads "2102." Maybe there's yet a third ID assigned to some 6.8µF caps.(?)
2) There's an additional hole drilled that could accommodate a cap having longer lead spacing. Perhaps 2102 differs by having a longer footprint, but the PCB design allows substituting 1611 sized caps. In which case that Roederstein MKT1822 series capacitor might actually be catalogued by Canton as 1611.
It's a mystery I'm still researching, hoping to definitively update the schematic in post #49. Fill free to modify the schematic any way you feel is useful. You're obviously adept with digital graphics. And crossover assembly details are at your fingertips.
