Hi,
I purchased a pair of Mission M790 speakers about 12 years ago. Recently one of the speakers stopped working. I removed the crossover and using a multimeter identified that two of the capacitors had failed. I have attached photos identifying the capacitors that are no longer working.
Details of the failed capacitors are as follows;
Capacitor 1 (blue capacitor in photos)
Anyway, I'm having a hard time trying to track down Caps with these specs. I live in New Zealand and there isn't a huge range of Capacitor suppliers over here. For Cap 1 I've found a 22uF 63V Cap but its Polarised. For Cap 2 Ive found a 10uF 100V Cap which is also Polarised.
Questions:
How can I confirm whether my caps are polarised or non-polarised?
If they are non-polarised, does it matter if I use polarised?
Can I use a 10uF 100v cap instead of an 8uF 100V cap?
Many thanks in advance for any assistance!
Cheers,
Steve
View attachment 2543180 View attachment 2543181 View attachment 2543182
- Identified as “C4” on crossover board
- 22uF
- 63V
- NP105 degrees C
- Type: Radial
- Distance between wires: 5mm
- Length: 15mm (excluding wires)
- Diameter: 10mm
- Identified as “C5” on crossover board
- 8uF
- 100V
- NK105 degrees C
- Type: Radial
- Length: 13mm (excluding wires)
- Diameter: 10mm
Questions:
Cheers,
Steve
