@Anthony8181
Just be aware that you really don't need to spend so much, to get fantastic sound from your TECHNICS' medium weight tonearm.
If I were in your shoes, I would spend less on a HIGH-OUTPUT MOVING COIL cartridge, which will NOT require an additional MC Step-up purchase.
I highly recommend this journey below...
Purchase a brand-new genuine DENON DL-110 - at low cost, compared to any of the HANA cartridges.
The DENON DL-110 is a proven top performer on your TECHNICS tonearm and sports one of the best styli in the business.
Setup the DL-110, according to the manufacturer's specifications, as follows:
47K Impedance Load (50K on your 9100)
2.0g VTF
Tonearm parallel to record surface
It will sound totally shite fresh out of the box.
Once you have about 4-hours play-time on your (test) hack pressings - and the DENON starts to sound quite decent - make the following changes:
Set the Impedance Loading to 100R (SHOCK!) - your PIONEER 9100 supports that option.
(Carefully) Remove the stylus guard
Give it a listen and appreciate the flawless tracking and the utterly quiet presentation and then become unhappy with the slightly too polite presentation...
And then:
Reduce the VTF to 1.6g!
You will now have a cartridge that takes wing and sings like a bird - and is as quiet in the grooves as our beloved (and costly) SHELTER 501/2!
The DENON DL-110 will sound fantastic, but won't fully come on-song until around 20-hours of play-time.
[I keep a tally mark in a small notebook, for each side. 3-sides represented by three tally marks = 1-hour of stylus life. Works for me...]
We are running this same cartridge at the moment on our high-spec hot-rodded LP12 rig - and are totally blown-away with the stunning sound quality!
The DENON DL-110 sound is smooth, but punchy and extended - without being a forensic detail machine. Tops are crystal clear - even with our all-tube rig - but are completely without fatigue. Bass and mids are the highlight here and the ever-so-slight warmth gives a sense of weight and fullness that we really enjoy. Drums sound like wood on skin and guitars have bodies. Female vocals have chest and brass sections sound metallic and blatty.
Best of all, your precious vinyl will thank you for the reduced VTF, the superb tracking and complete absence of groove-wall collisions - even on the inner tracks.
Then go and spend the balance of your cartridge budget on NEAR MINT original pressings!
IMPORTANT: To really hear the truth of your cartridge performance at each stage, perform critical listening with headphones. Even budget headphones have way less distortion than the most exotic of loudspeakers - so you will hear the whole truth and nothing but the truth. A cartridge that sounds stunning on headphones, will sound sensational on loudspeakers.
