Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
I have an old MCS model 3570 and an MCS receiver that match and the cassette plays but stops by itself during playback. I have cleaned the rollers and heads and tried different cassette tapes. Any ideas? Thanks
I had this problem in a Denon and it turned out being the tire that changes from the take up spool to the supply spool. When driving the take up spool it would eventually slip and the drive would stop. If you have this type of design clean up the roller and maybe add some restorer to it and you might be set to go.
Good Luck :thmbsp:
