Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
With out a pic it's hard to figure what you are referring to on the tweeter.
The black screen covering the acetate dome?
If so the screen should be removed to check for damage or impingement of the dome.
I have Celestions with metal dome tweeters that were pushed in.
I disassembled them and pushed them out from the inside. The metal domes where all crinkled so I just smoothed them out with a small ball shaped object.
For your consideration - YMMV.
If it's bad enough you need to de-solder the wires and remove the diapragm from the magnet body. This involves carefully dislodging the diaphragm, which is attached by way of sticky double sided tape, and hopefully be able to reform the dome from the inside out.
