Yes ebay, from france.hi,probably put the new coil membrane in place on the tweeter between the 4 half moon pin,put some glue on the back of cardboard,press it in place and holding until it dry using the bigger cardbooard circle.Please tell me did you get from ebay these coils, Yvan
The VC ring looks burnt. These diaphragms may just be a short term solution to a long term problem unless someone accidentally blew them.
Hi,these come from Ditton Celestion? My only concern about the new coil it's a 8 ohm,usually supose to be 4 ohm?Yvan
then you need to change the caps on the cross over,do a goggle search for hf2000 replacement tweeters for more info.
That's how tweeters normally blow, by accident. The "burn" is probably just residue from the old dome when it blew. The supertweeters were all gone, I had them rewound.
Did it work for you?
Having been around for more than ten decades and not seen any postings in regards to a successful Celestion diaphragm replacement, probably added another decade to my ageThis thread is nearly 2 years old, please don't be surprised if you do not get a reply.
I try to be nice to our most elderly members as I see you are 116 years old
but no one apparently reporting good or bad ...
They worked for me, at least the ones I got.I Bought a pair of replacement diaphragms for a pair of Celestion HF2000 from Nino Music in France recently.
The quality of the replacements seems fine, and mimics the originals visually.
Nino has put a bit of effort into giving advice on how to carry out the replacement, in addition to the youtubes he has provided. However, following all his instructions, the replacement coils seems to be a bit too narrow and doesn't seem to fit the Celestion HF2000 I have at hand. (Beovox 5700)
I'm still here! This is the second old thread of mine bumped in the past few days.This thread is nearly 2 years old, please don't be surprised if you do not get a reply.
Just barely - it doesn't pop in, like Nino Music shows in his video's, and like the old cook'ed one does. The old one has a bit of play whereas the new one feels pretty tight.They worked for me, at least the ones I got.
Does the coil not fit into the gap?
