Center channel ? Battle of bottom shelf ?Sad times
Status
Not open for further replies.
ultumax
Bottom shelf battle ???
I got randomness to choose from
And Phillips Magnovox but it’s the lightest one so .... probably won’t be using that .
No Santa midranges this time , and grilles all suck non removable .C47DA4D9-FAE3-4DE4-B4E7-6F6DD886845E.jpeg97A46EEC-1822-4F31-A19C-2BFEA34CFC95.jpegCCEEEF62-A8FD-431C-BC46-526D5F0B1505.jpeg1004A174-F4C5-42BE-A361-1876B5A524CF.jpeg3248066A-2925-4950-B292-DA7FE1C06924.jpeg79D5450B-834E-440F-A2C4-E7894DC0CAD4.jpegA2B8FDB4-9E15-4A04-AA70-3643D201CA17.jpeg6B3CC8C4-0A83-49AB-AB93-0385DF25B8F1.jpeg
Shock and awe , can’t afford a klipsch center right now . Or something clearer, ‘‘tis is for my downstairs system , sad times .:(:eek::yikes:
Any idea ? Or just test each out for a day
This receiver does not have phantom mode .
What are your main (front left, front right) speakers? I would say that matching your center to your front mains is going to be the most important. Even if it's not the "best" center on it's own, if it matches better with your mains then it should be better for your system.
989596D7-5AE8-4CC4-A7AD-CF97F6A7ED35.jpeg 2180C59D-A350-4394-851E-10CC0A56AFC8.jpeg 25EE6456-7A0B-4569-B20E-704ADBFE9A7F.jpeg 3BC19741-D70B-4B1A-B790-3FF370157B49.jpeg 21003775-FE2C-452A-894D-353AB5703D89.jpeg L
thats the dilemma my matching center is in my bedroom , but it does not sound well with my tower speakers . Look at my bedroom system .
If brought it downstairs , what would I replace it with in my bedroom? I cannot afford another floorstander or a higher end klipsch center.
Might be easier to use my sony speakers or rca fronts, they are voice matched .
Is it ok for rear surround facing from front if you have no way to wall mount them. ? I have then sitting on top of fronts .
Maybe try the original speakers for a while ?
Sure it's okay but it isn't the correct way to use them, the results will be less than satisfactory.
Yeah how on earth do you move surrounds to back the wires are so annoying . Wish I had a cheap wireless speaker router .
Pictures of klipsch icon then center sounds harsh compared to floor-standersCC158A01-01CC-4BC1-8F7D-18349578BEE8.jpeg 77C99818-F230-403E-AB6D-6DFD4132C099.jpeg 5982B535-DE19-4020-99A1-BF379BC7653F.jpeg BFD443CC-132E-4F87-A3EC-690484335F36.jpeg 4E5B1BE4-7877-45DF-9D6D-7F44B5BA832D.jpeg 146FA0FD-9A53-4CA0-B289-EB8EE2454E8A.jpeg . With my onkyo it may work with tHis Sony .
Still angry I got the smaller floorstanders for my bedroom . If I had got larger one could forgo the center channel.
Probably best to just run in 2channel/stereo mode (if you can) until you buy wire and get the surrounds behind you.
Do you think my bedroom system would sound better without a center ? Or no would it still do 7 channels .
How do you hide the wires ?? For surrounds.
I may try the Sony’s , but odds are I’m going back to klipsch.
I think so as long as your main speakers have good a midrange. I'll take stereo mode with speakers that can reproduce decent vocals over 5.1 with a center speaker that can't...and a lot of them can't.
As for hiding wires, tuck them under the carpet or carefully under the baseboards.
May be to add carpeting , sucks My friend threw out all my carpet scraps . I got none . Yeah what about 7ch on my room klipsch icon center can often sound strained as it’s sealed .
  • Looks like a centipede poking its head out !!!!
  • 29200A79-94BA-4A97-A9D1-79975622DF7E.jpeg A414CE17-B35A-4746-8668-DE490113074F.jpeg 580B75B6-2184-41D2-98F9-DB8587E65E2C.jpeg 1F4C2B3F-B84B-4E24-9673-E1A53EC5B324.jpeg 17CEFF29-1BF0-4B96-A59B-E352F6928A83.jpeg 1B0F2001-0C56-4C8A-84BE-EE4CA56D82C3.jpeg 7A2FEAD5-9573-4782-A5AD-C4198CA3ED86.jpeg How do you do not the speaker wires in back of these ? Do I need to drill part out with a circle bit???
Save the banana mugs ?!!!:banana::banana::jump:
More JUNK that is all:)
You obviously can't stay away from it can you?
It’s a old system was in garage you sure they won’t sound good ? Why do Sony woofers slightly yellow as they get older .
Probably better of running 2 ch klipsch.
Pioneer sounds the best so far .
This is probably the hardest avr to find speakers to use with .
The klipsch May be over bright and it does not have enough treble lowering controls .
There fine except for stereo 2 ch . This avr turns them into like PA speakers .
I’ll keep trying but to find a working set up .
They might still be my best option.
Why HE persists in buying all this JUNK and still looks for more? Why can't he keep what he has that's good and forget, the what seems like the impossible for him? Oh well that's his FATE I guess:)
YOu weren’t reading I said every set up sucked....FB8146E6-C387-4B29-99EE-CF28356C710B.jpeg 912B38FA-CA6C-4EA8-A54C-3C32F387FC9B.gif
It’s better then tv speakers . ?
Status
