Hello, have a pair of CV model 26 that I bought new in 1977. I had CV repair the surrounds in 1980 (rotted out) and now I notice there is a voice coil rubbing in one woofer.
The woofer is a 12" model 2723 (according to Gibson/CV) steel stamped frame 60Wrms w/1.6" voice coil. The sales brochchur/spec sheet showed them as "L121 12" (30cm) 1.6" (4cm) voice coil, 22Hz resonance, 7lb (3.2Kg) magnet system".
Does anyone know where I can get the repair kit for this? Simply Speakers does not carry it. If I decide to replace both woofers together, what would be a good upgrade? I measured 6.6 ohms on the speaker alone. Is there a highly efficient replacement with similar specs or better? Should I go to the cast frame CV171 (they might be 4 ohms)? Or an Eminence or Celestion or ?
Thanks
Thanks
