CerwinVega Question
I recently picked up a pair of 1965 Wharfedale W60 2-way's from a private party for $50.00. Very nice cabinets and very very nice sound. Am using them in place of my Spica TC60's for the time being. I'm thinking of replacing the caps. as these are 40 years old. There are 2 silver caps. and a choke per crossover. But I can't read the value on the caps. One is smaller than the other. Can anyone help me out here? Thanks.
Archie
gibsonian try www.cerwinvega.com they gave me specs om my 211 r 's i was refurbishing ask them about a spec sheet they will also give you email adresses of companies that are certified repair centers also good lluck
I believe it's 700 and 4500 but I can't remember for sure.
If you do a search for them I believe someone had posted it in a thread I saw on them.
Thanks for the tips. I did contact CerwinVega for the specs. and here they are (complete) for anyone that's interested. I was surprised to see that they are 4 ohm impedance.
DIGITAL DESIGN SERIES
MODEL D-9
DESCRIPTION: 15” 3-WAY LOUDSPEAKER
FREQUENCY RESPONSE: 29 Hz –20 kHz
POWER HANDLING: 5/350 Watts RMS Min/Max
SENSITIVITY: 101 dB (1 Watt @ 1 Meter)
IMPEDANCE: 4 Ohms
LF DRIVER: 15” Die-cast Frame / 2” Voice-Coil (152WR)
MF DRIVER (upper): 6” Cone (M-6 or CM-6)
MF DRIVER (lower): 6” Cone (M6-H or CMR-H)
HF DRIVER: 1” Voice-Coil Horn Tweeter (CS-5)
PROTECTION: Circuit Breaker (Tweeter)/Fuse (Overall)
LEVEL CONTROLS: Tweeter & Midrange
CROSSOVER POINTS: 500/3500 Hz.
DIMENSIONS: 35” X 18” X 17.75” ( H X W X D )
WEIGHT: 85 lbs.
PRODUCED: 1983 - 1992
