cwh
33
A pair of 1970s project Acoustic Research 2ax speakers have joined the fray. Although I'm working on three other speaker projects, adding the ARs into the mix should be doable.
Their overall condition is pretty good given they were headed for the dump. Cabinets are structurally sound and the defects are superficial. Edges and corners have fared well with only one corner crush. I'll repair however, if positioned vertically that corner would sit on the bottom rear. 90% of the veneer will only need a simple refinish with the rest requiring finicky touch up. One speaker came with the grill partially removed via a finger hole in the cloth. The other is hole free. I'm encouraged to put a little time into saving the linen.
I'll get into the drivers and electronics once I remove the woofers and stuffing.
Once nice aha moment came when I realized I have a pair of Rick Cobb's filleted 10" surrounds waiting for a BA project that's missing a woofer. I believe that's the one I want for the ARs, right? I'd be so lucky to have crossover caps too but I'm pretty sure I just depleted my 2ufs and 4ufs on another project.
Thanks for checking in
