Fisher adds magic to everything.
Biggles
If you do this by disconnecting the rear external jumper wire, you're going to lose the mid driver as well, essentially re-creating a woofer-only AR speaker like you've already done with the AR-2's. I'm not saying the JansZen's can't be made to augment the 2ax, which already has a designated "super-tweeter", but I don't think that application was an intended use for the separate tweeter array......since the tweeter can be disconnected.
The front-wired 2ax's share a common terminal, but I believe the rear-wired 2ax's have two separate internal wires for mid and tweet. With either version, you'll have to disconnect a wire and take the tweeter out of the circuit if you're trying to play only the woofer and midrange with the JansZen's, and you'll need to keep the jumper wire in place....what would be the best way of implementing the 130 without eliminating the mid driver?
The paper labels on the backside of the speakers clearly offer directions "To convert to woofer only....", but I've never been fully clear about why or how often owners hooked up their speakers using this option. Even the early AR-6's have three terminals and jumper wire, and these are two-way speakers with an 8" woofer....why did AR give owners the option of disconnecting the rear jumper wire back in the day ?
Hey,
Me too on the tubes, especially the Fisher. I know they'd suck my Pioneer SX-1000TW dry, the AR4x's did. First volume spin, gone. Vintage tube power is where the AR's want to be.
Biggles
AR-2ax is definitely a tuber. Jazz and soul, they don't really like to rock. Aretha Franklin, whoa.
Like the OP has used, Dayton poly caps offer an excellent value, so here are some suggestions for one-stop shopping. You could use a 6.2uF cap or parallel two 3.0uF caps for the midrange, and the 4.0uF is for the tweeter. If you choose to replace the original pots with new L-pads, it's advisable to add a 25 ohm resistor on the midrange to more precisely re-create the performance of the pot. Doing the same on the tweeter L-pad is generally not recommended since these drivers have most likely weakened and it's often nice to get as much HF from them as they can deliver....looking for suggestions on parts source...
I've used the same L-pads but from PE for around 5 bucks each. Vintage ar prices are silly for those. I used them in a set of 2as and they worked perfectly. Keep in mind the wires hook up in a different sequence on the tabs than the originals.I'm in the process of restoring an identical set of AR 2ax speakers, looking for suggestions on parts source and correct upgrades for crossover capacitors, also, Vintage-AR sells replacement L-pads that do not look like the originals (originals have red adjustment posts, his have a dial that affixes to the post, and his have more adjustment points) but he claims they are better, anyone have any experience with them?
Good call, whoa indeed.Aretha Franklin, whoa.
