Parts Express now sells replacement woofers made especially for the Mach One.
Thanks for that reply, and I would like to make a new more clear post.
I needed all Mach Ones owners attention :nono:
I made a post about it with no replies except the above quote. I think there is a problem with the knowledge of the 4029 woofer.
This is what evidence is starting to show. I believe Parts Express made a big mistake maybe.
My woofer from an original 4029 I bought new back in ~1983 says 6 ohms on the back, and measures 6 ohms. I am reading of some who have the same 6 ohm driver. If there are 4 ohm drivers (still has the sticker that says 4 ohms on the woofer) than RadioShack made two versions. Can anyone show a pic of a 4029 woofer with 4 ohms on it?
I was thinking well maybe Parts Express measured at the crossover freg or... something different. But its business practise to state the nominal ohms of a driver so folks know. It should have been rated 6 ohms, unless they just went by what others say on forums. Many people just may have wrong info. I notice there are not too many original Mach One 4029 owners; as I am of almost 30 years and babied them for 30 years... and was into them for a long time and am again into them (a lifetime passion :sigh
If you look at my pick of the crossover you will see it has very different values compared to the 8 ohm version from what I read(?), and is made for the lower impedance driver of 6 ohms. Replacing it with a real 4 ohm driver will cause problems. Its hard to figure the exact crossover of the Mach Ones (4029) woofer. Its a 2nd order crossover with a 33uf cap and 1mh coil, for 4ohms this would be 800Hz but its not crossed over that low (from actually speaker measurements; test tones, spl measurements) and is crossed over in the 1-2k range, and its rated by RS at 1.2khz. Speakers have dynamic impedance so I could not figure it out without more info.
The real point is did Parts Express copy the second generation Mach One 4029 woofer right? Or did they go by forum posts saying its 4ohms?
I do believe PE had one Mach One woofer and reversed engineered it, the first generation. I am not sure if they had a 4029 woofer, even if they did and every-one's 4029 woofers say 6 ohms it should have been labeled as such. Kinda crazy to argue about speakers I have owned for almost 30 years LOL.:thmbsp:
How many have 4029 Mach Ones with 4ohms on the back of the woofer? Could you show a pic?
It would be nice to compile one post with all the facts we know of the Mach Ones.
. He said it just depends on if your amp can handle it. When I said it does use a 2nd order cross-over he said "oh, its not on our data sheets". Parts Express had bad info it seems. When I told him that would alter the cross-over point he said it would not be a big deal and said its just a replacement woofer.
